12 years agoAccessing SDRAM memory on Terasic DE0-Nano board.
I want to use SDRAM memory located on DE0-Nano board using Verilog (without using Nios). I use http://www.altera.com/support/examples/nios2/exm-avalon-mm.html System placed in the QSYS: htt...
11 years agoI'am not used this board for long time, but this should work:
module SRAM(
CLOCK_50, LED, KEY,
DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_DQM, DRAM_RAS_N, DRAM_WE_N //Memory pin
//////////// CLOCK //////////
input CLOCK_50;
//////////// LED //////////
output LED;
reg LED;
//////////// KEY //////////
input KEY;
//////////// SDRAM //////////
output DRAM_ADDR;
output DRAM_BA;
output DRAM_CAS_N;
output DRAM_CKE;
output DRAM_CLK;
output DRAM_CS_N;
inout DRAM_DQ;
output DRAM_DQM;
output DRAM_RAS_N;
output DRAM_WE_N;
//////////// AVALON CONNECTOR //////////
wire qsys_sdram_read_control_fixed_location;
wire qsys_sdram_read_control_read_base;
wire qsys_sdram_read_control_read_length;
wire qsys_sdram_read_control_go;
reg reg_qsys_sdram_read_control_fixed_location;
reg reg_qsys_sdram_read_control_read_base;
reg reg_qsys_sdram_read_control_read_length;
reg reg_qsys_sdram_read_control_go;
wire qsys_sdram_read_control_done;
wire qsys_sdram_read_control_early_done;
wire qsys_sdram_read_user_read_buffer;
reg reg_qsys_sdram_read_user_read_buffer;
wire qsys_sdram_read_user_buffer_output_data;
wire qsys_sdram_read_user_data_available;
reg gooff=0;
integer start=3;
qsys u0(
.clk_clk(CLOCK_50), //clk.clk
.reset_reset_n(1'b1), //reset.reset_n
.sdram_clock_c0_clk(DRAM_CLK), //sdram_clock_c0.clk
.sdram_clock_areset_conduit_export(1'b0), //sdram_clock_areset_conduit.export
.sdram_wire_addr(DRAM_ADDR), //sdram_wire.addr
.sdram_wire_ba(DRAM_BA), // .ba
.sdram_wire_cas_n(DRAM_CAS_N), // .cas_n
.sdram_wire_cke(DRAM_CKE), // .cke
.sdram_wire_cs_n(DRAM_CS_N), // .cs_n
.sdram_wire_dq(DRAM_DQ), // .dq
.sdram_wire_dqm(DRAM_DQM), // .dqm
.sdram_wire_ras_n(DRAM_RAS_N), // .ras_n
.sdram_wire_we_n(DRAM_WE_N), // .we_n
.sdram_read_control_fixed_location(qsys_sdram_read_control_fixed_location),
.sdram_read_control_read_base(qsys_sdram_read_control_read_base),
.sdram_read_control_read_length(qsys_sdram_read_control_read_length),
.sdram_read_control_go(qsys_sdram_read_control_go),
.sdram_read_control_done(qsys_sdram_read_control_done),
.sdram_read_control_early_done(qsys_sdram_read_control_early_done),
.sdram_read_user_read_buffer(qsys_sdram_read_user_read_buffer),
.sdram_read_user_buffer_output_data(qsys_sdram_read_user_buffer_output_data),
.sdram_read_user_data_available(qsys_sdram_read_user_data_available)
assign qsys_sdram_read_control_fixed_location = reg_qsys_sdram_read_control_fixed_location;
assign qsys_sdram_read_control_read_base = reg_qsys_sdram_read_control_read_base ;
assign qsys_sdram_read_control_read_length = reg_qsys_sdram_read_control_read_length ;
assign qsys_sdram_read_control_go = reg_qsys_sdram_read_control_go;
assign qsys_sdram_read_user_read_buffer = reg_qsys_sdram_read_user_read_buffer;
always @(posedge CLOCK_50)
begin
if (start==1)
begin
reg_qsys_sdram_read_control_fixed_location <= 0;
reg_qsys_sdram_read_control_read_base <= 0;
reg_qsys_sdram_read_control_read_length <= 2;
reg_qsys_sdram_read_control_go <= 1;
gooff <= 1;
end
if (gooff)
begin
gooff <= 0;
reg_qsys_sdram_read_control_go <= 0;
end
if (start) start = start - 1;
LED <= qsys_sdram_read_user_buffer_output_data ;
end
endmodule
