12 years agoAccessing SDRAM memory on Terasic DE0-Nano board.
I want to use SDRAM memory located on DE0-Nano board using Verilog (without using Nios). I use http://www.altera.com/support/examples/nios2/exm-avalon-mm.html System placed in the QSYS: htt...
12 years agoHello,
I want to write SDRAM through my custom hardware IP. I am using the Master Templates for this. I am writing using custom hardware and reading using NIOS, but my bios doesn't read the correct value. Below is my code for writing into SDRAM. I want to write on the click of a button (coe_switch[3]). I have one more doubt, "myBuffer_control_write_write_base" should be the base address for SDRAM or offset or base+offest. reg searchForSync; always @(posedge csi_clk or negedge rsi_rst) begin if(!rsi_rst) begin click <= 0; searchForSync <= 0; end else begin if(coe_switch[3] == 0) begin searchForSync <= 1; myBuffer_control_write_fixed_location <= 0; myBuffer_control_write_write_base <= 32'h00000000; myBuffer_control_write_write_length <= 8; myBuffer_control_write_go <= 1; myBuffer_user_write_buffer_input_data <= 1; myBuffer_user_write_write_buffer <= 1; end if(searchForSync == 1) begin myBuffer_user_write_buffer_input_data <= 1; myBuffer_user_write_write_buffer <= 1; myBuffer_control_write_go <= 0; if(asi_stin_sop_reg[319] == 1) begin end end end end Please let me know if I am doing something wrong. Please suggest.
