11 years agoOkay, here's my latest.
The first 7 segment counts down, but the others don't appear to do anything. I think it's the way I am mapping the counter, or the count variable isn't adding up the way I think it should. Thanks in advance! D
// Mapping down the seven segment LED to perform a clockwise "Predator"ish symbol countdown.
//Begin Module
module whileBinary_to_led (
// Create input from the clock.
input bin_counter,
// Create output busses for the counters.
output reg counter_out,
output reg counter_out2,
output reg counter_out3,
output reg counter_out4);
integer count = 0;
always @ *
begin
counter_out = 7'b0000000;
counter_out2 = 7'b0000000;
counter_out3 = 7'b0000000;
counter_out4 = 7'b0000000;
if (count <= 6) begin
case (bin_counter)
// output to Hex0
3'b001 : counter_out = 7'b0000000; //
3'b010 : counter_out = 7'b0010000; //
3'b011 : counter_out = 7'b0011000; //
3'b100 : counter_out = 7'b0011100; //
3'b101 : counter_out = 7'b0011110; //
3'b110 : counter_out = 7'b1011110; //
3'b111 : counter_out = 7'b1111110; //
default : counter_out = 7'b1111111;
endcase
end
if ((count > 6) && (count <= 13)) begin
case (bin_counter)
// output to Hex0
3'b001 : counter_out2 = 7'b0000000; //
3'b010 : counter_out2 = 7'b0010000; //
3'b011 : counter_out2 = 7'b0011000; //
3'b100 : counter_out2 = 7'b0011100; //
3'b101 : counter_out2 = 7'b0011110; //
3'b110 : counter_out2 = 7'b1011110; //
3'b111 : counter_out2 = 7'b1111110; //
default : counter_out2 = 7'b1111111;
endcase
if ((count > 13) && (count <= 20))
case (bin_counter)
// output to Hex0
3'b001 : counter_out3 = 7'b0000000; //
3'b010 : counter_out3 = 7'b0010000; //
3'b011 : counter_out3 = 7'b0011000; //
3'b100 : counter_out3 = 7'b0011100; //
3'b101 : counter_out3 = 7'b0011110; //
3'b110 : counter_out3 = 7'b1011110; //
3'b111 : counter_out3 = 7'b1111110; //
default : counter_out3 = 7'b1111111;
endcase
if ((count > 20) && (count <= 27))
case (bin_counter)
// output to Hex0
3'b001 : counter_out4 = 7'b0000000; //
3'b010 : counter_out4 = 7'b0010000; //
3'b011 : counter_out4 = 7'b0011000; //
3'b100 : counter_out4 = 7'b0011100; //
3'b101 : counter_out4 = 7'b0011110; //
3'b110 : counter_out4 = 7'b1011110; //
3'b111 : counter_out4 = 7'b1111110; //
default : counter_out4 = 7'b1111111;
endcase
end
count = count + 1;
end
endmodule// end of module counter
