13 years ago
about vhdl code for cic interpolation filter
i am attaching one pdf file based on cic filter.In the bitgrowth section the author has mentioned about the increase in the bits at the output stage .Suppose if i am writing a vhdl code for cic interpolation stage for example let differential delay M=1, Interpolation factor R=8,Input bit size be 23 and number of comb sections and integrator sections be N=9.Then how the output bit size change for each comb section.Can anybody explain me with the above mentioned parameters?
    --- Quote Start ---
    The final output ifilterout33 is coming as undefined . I tried as you said.But still there is problem in the output.
    --- Quote End ---
    I guess you are talking about functional simulation resuts? The uninitialized register ifilterout32 is propagating to the last integrator stage.
    You need to initialize all register variables in functional simulation.
    --- Quote Start ---
    --- Quote End ---
    Is the initialization that i have done in the given code is not enough?
    You are right, I didn't look thoroughly at the code. In this case, I expect that "undefined" is propagating from din. You'll need to look at the exact waveforms for each register to identify where undefines comes from, ore use a respective trace function in Modelsim.
    I also noticed that it's apparently a Xilinx project. This is not the right forum to get help for possible problems with Xilinx tools.
