9 years ago
About VGA Output
I am working for the first time with FPGA (cyclone v soc) and i am trying to get a output from VGA Port on the monitor. I have set the resolution for 1024x768 and PLL input frequency as 50MHz and output frequency as 65MHz as required for the resolution.But as soon as i program the board the monitor is going to sleep mode. I am attaching the code which i used for this. Can you please tell me what may be the problem. When I checked in RTL Simulation PLL is not generating any clock output.
Thank you in advance.
Code:
----Main code
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY VGA IS
PORT(
CLOCK_24: IN STD_LOGIC;
SYS_rst : IN STD_LOGIC;
VGA_HS, VGA_VS: OUT STD_LOGIC;
VGA_R, VGA_G, VGA_B: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
VGA_CLK_65MHZ : OUT STD_LOGIC
END VGA;
ARCHITECTURE MAIN OF VGA IS
SIGNAL VGACLK, RESET, lock : STD_LOGIC :='0';
signal SIGNAL_135MHZ : STD_LOGIC:= '0';
COMPONENT SYNC IS
PORT
CLK : IN STD_LOGIC;
HSYNC, VSYNC : out std_logic;
R, G, B : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
component unsaved is -- PLL Component
port (
pll_0_locked_export : out std_logic; -- pll_0_locked.export
pll_0_outclk0_clk : out std_logic; -- clk
pll_0_refclk_clk : in std_logic := '0'; -- clk
pll_0_reset_reset : in std_logic := '0' -- reset
end component unsaved;
BEGIN
inst_pll : UNSAVED port map
pll_0_refclk_clk => clock_24,
pll_0_reset_reset => SYS_rst,
pll_0_outclk0_clk => VGACLK, ---CLOCK 65 MHZ
--outclk_1 => SIGNAL_135MHZ, --- CLOCK 135 MHZ
pll_0_locked_export => lock
INST_SYNC : SYNC PORT MAP
CLK => VGACLK,
HSYNC => VGA_HS,
VSYNC => VGA_VS,
R => VGA_R,
G => VGA_G,
B => VGA_B
VGA_CLK_65MHZ <= VGACLK;
END MAIN;
---Sub Program
LIBRARY IEEE;
ENTITY SYNC IS
PORT(
CLK : IN STD_LOGIC;
END SYNC;
ARCHITECTURE MAIN OF SYNC IS
SIGNAL HPOS: INTEGER RANGE 0 TO 1344:=0;
SIGNAL VPOS: INTEGER RANGE 0 TO 806:=0;
BEGIN
PROCESS(CLK,HPOS,VPOS)
BEGIN
IF(CLK' EVENT AND CLK='1') THEN
IF (HPOS = 832 OR VPOS = 422) THEN
R <= (OTHERS => '1');
G <= (OTHERS => '1');
B <= (OTHERS => '1');
ELSE
R <= (OTHERS => '0');
G <= (OTHERS => '0');
B <= (OTHERS => '0');
END IF;
IF(HPOS<1344) THEN
HPOS <= HPOS+1;
ELSE
HPOS <=0;
END IF;
IF (VPOS<806)THEN
VPOS <= VPOS+1;
ELSE
VPOS <=0;
END IF;
END IF;
IF (HPOS > 24 AND HPOS < 160)THEN
HSYNC <= '0';
ELSE
HSYNC <= '1';
END IF;
IF (VPOS > 3 AND VPOS < 9) THEN
VSYNC <= '0';
ELSE
VSYNC <= '1';
END IF;
IF ((HPOS> 0 AND HPOS< 320) OR (VPOS>0 AND VPOS< 38)) THEN
END IF;
END PROCESS;
END MAIN;
