10 years agoAbout VGA Output
I am working for the first time with FPGA (cyclone v soc) and i am trying to get a output from VGA Port on the monitor. I have set the resolution for 1024x768 and PLL input frequency as 50MHz and output frequency as 65MHz as required for the resolution.But as soon as i program the board the monitor is going to sleep mode. I am attaching the code which i used for this. Can you please tell me what may be the problem. When I checked in RTL Simulation PLL is not generating any clock output. Thank you in advance. Code: ----Main code LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; ENTITY VGA IS PORT( CLOCK_24: IN STD_LOGIC; SYS_rst : IN STD_LOGIC; VGA_HS, VGA_VS: OUT STD_LOGIC; VGA_R, VGA_G, VGA_B: OUT STD_LOGIC_VECTOR(7 DOWNTO 0); VGA_CLK_65MHZ : OUT STD_LOGIC ); END VGA; ARCHITECTURE MAIN OF VGA IS SIGNAL VGACLK, RESET, lock : STD_LOGIC :='0'; signal SIGNAL_135MHZ : STD_LOGIC:= '0'; COMPONENT SYNC IS PORT ( CLK : IN STD_LOGIC; HSYNC, VSYNC : out std_logic; R, G, B : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) ); END COMPONENT; component unsaved is -- PLL Component port ( pll_0_locked_export : out std_logic; -- pll_0_locked.export pll_0_outclk0_clk : out std_logic; -- clk pll_0_refclk_clk : in std_logic := '0'; -- clk pll_0_reset_reset : in std_logic := '0' -- reset ); end component unsaved; BEGIN inst_pll : UNSAVED port map ( pll_0_refclk_clk => clock_24, pll_0_reset_reset => SYS_rst, pll_0_outclk0_clk => VGACLK, ---CLOCK 65 MHZ --outclk_1 => SIGNAL_135MHZ, --- CLOCK 135 MHZ pll_0_locked_export => lock ); INST_SYNC : SYNC PORT MAP ( CLK => VGACLK, HSYNC => VGA_HS, VSYNC => VGA_VS, R => VGA_R, G => VGA_G, B => VGA_B ); VGA_CLK_65MHZ <= VGACLK; END MAIN; ---Sub Program LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; ENTITY SYNC IS PORT( CLK : IN STD_LOGIC; HSYNC, VSYNC : out std_logic; R, G, B : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) ); END SYNC; ARCHITECTURE MAIN OF SYNC IS SIGNAL HPOS: INTEGER RANGE 0 TO 1344:=0; SIGNAL VPOS: INTEGER RANGE 0 TO 806:=0; BEGIN PROCESS(CLK,HPOS,VPOS) BEGIN IF(CLK' EVENT AND CLK='1') THEN IF (HPOS = 832 OR VPOS = 422) THEN R <= (OTHERS => '1'); G <= (OTHERS => '1'); B <= (OTHERS => '1'); ELSE R <= (OTHERS => '0'); G <= (OTHERS => '0'); B <= (OTHERS => '0'); END IF; IF(HPOS<1344) THEN HPOS <= HPOS+1; ELSE HPOS <=0; END IF; IF (VPOS<806)THEN VPOS <= VPOS+1; ELSE VPOS <=0; END IF; END IF; IF (HPOS > 24 AND HPOS < 160)THEN HSYNC <= '0'; ELSE HSYNC <= '1'; END IF; IF (VPOS > 3 AND VPOS < 9) THEN VSYNC <= '0'; ELSE VSYNC <= '1'; END IF; IF ((HPOS> 0 AND HPOS< 320) OR (VPOS>0 AND VPOS< 38)) THEN R <= (OTHERS => '0'); G <= (OTHERS => '0'); B <= (OTHERS => '0'); END IF; END PROCESS; END MAIN;28 Replies
PLL reset is usually an active high signal. Please check that. It could be the problem Regards, Bhavya K - Altera_Forum
thank you so much for your reply. i Tried with that but same problem exists. Can you please check the program once..? is there any problem with code...?
waiting for your reply regards, Prashanth - Altera_Forum
I don't quite understand the sync code. The resolution is XGA(1024x768) but your HPOS and VPOS maximum values are 800 and 525 which is not proper. - Altera_Forum
hello,
I am really sorry i had done the programming for 640x480 and 1024x768 resolutions. had forgot to change the values. Now i have changed the values. am really sorry for this. Even for the values of resolution 1024x768 im not getting any clock output regards Prashanth - Altera_Forum
Clock output is from the PLL. So where are you checking this clock? Are you probing or checking in simulation? The only reason should be that either the input clock or reset has a problem. Im not seeing any other reason for not getting the clock output - Altera_Forum
hello,
yes. i am checking that clock in Modelsim Altera starter edition 10.4b version. I have written the test bench program to check the output in modelsim. test bench code: LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; ENTITY VGA_TB IS END ENTITY VGA_TB; ARCHITECTURE BEHAVIOUR OF VGA_TB IS SIGNAL CLOCK_24: STD_LOGIC:= '0'; SIGNAL SYS_rst : STD_LOGIC:= '1'; SIGNAL VGA_HS, VGA_VS: STD_LOGIC:= '0'; SIGNAL VGA_R, VGA_G, VGA_B: STD_LOGIC_VECTOR(7 DOWNTO 0):= (OTHERS => '0'); SIGNAL VGA_CLK_65MHZ : STD_LOGIC:= '0'; COMPONENT VGA IS PORT ( CLOCK_24: IN STD_LOGIC; VGA_HS, VGA_VS: OUT STD_LOGIC; VGA_R, VGA_G, VGA_B: OUT STD_LOGIC_VECTOR(7 DOWNTO 0); VGA_CLK_65MHZ : OUT STD_LOGIC ); END COMPONENT; BEGIN INST_VGA : VGA PORT MAP ( CLOCK_24 => CLOCK_24, VGA_HS => VGA_HS, VGA_VS => VGA_VS, VGA_R => VGA_R, VGA_G => VGA_G, VGA_B => VGA_B, VGA_CLK_65MHZ => VGA_CLK_65MHZ); CLOCK_PROC : PROCESS BEGIN CLOCK_24 <= '0'; WAIT FOR 10 NS; CLOCK_24 <= '1'; WAIT FOR 10 NS; END PROCESS; SYS_rst <= '0', '1' AFTER 100 NS; END; - Altera_Forum
Change the reset generation to
SYS_rst <= '1', '0' AFTER 100 NS; Please attach simulation waveform snapshot if this does not work - Altera_Forum
Please check this link as to how to simulate the altera PLL
https://www.altera.com/support/support-resources/design-examples/design-software/simulation/modelsim/exm-pll-simulation.html - Altera_Forum
Thank you so much for helping me. But i could not follow the instructions given there. If you don't mind can you please check my project file which i am attaching here...? regards, Prashanth
