10 years agoAbout VGA Output
Hello, I am working for the first time with FPGA (cyclone v soc) and i am trying to get a output from VGA Port on the monitor. I have set the resolution for 1024x768 and PLL input frequency as ...
10 years agohello,
yes. i am checking that clock in Modelsim Altera starter edition 10.4b version. I have written the test bench program to check the output in modelsim. test bench code: LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; ENTITY VGA_TB IS END ENTITY VGA_TB; ARCHITECTURE BEHAVIOUR OF VGA_TB IS SIGNAL CLOCK_24: STD_LOGIC:= '0'; SIGNAL SYS_rst : STD_LOGIC:= '1'; SIGNAL VGA_HS, VGA_VS: STD_LOGIC:= '0'; SIGNAL VGA_R, VGA_G, VGA_B: STD_LOGIC_VECTOR(7 DOWNTO 0):= (OTHERS => '0'); SIGNAL VGA_CLK_65MHZ : STD_LOGIC:= '0'; COMPONENT VGA IS PORT ( CLOCK_24: IN STD_LOGIC; VGA_HS, VGA_VS: OUT STD_LOGIC; VGA_R, VGA_G, VGA_B: OUT STD_LOGIC_VECTOR(7 DOWNTO 0); VGA_CLK_65MHZ : OUT STD_LOGIC ); END COMPONENT; BEGIN INST_VGA : VGA PORT MAP ( CLOCK_24 => CLOCK_24, VGA_HS => VGA_HS, VGA_VS => VGA_VS, VGA_R => VGA_R, VGA_G => VGA_G, VGA_B => VGA_B, VGA_CLK_65MHZ => VGA_CLK_65MHZ); CLOCK_PROC : PROCESS BEGIN CLOCK_24 <= '0'; WAIT FOR 10 NS; CLOCK_24 <= '1'; WAIT FOR 10 NS; END PROCESS; SYS_rst <= '0', '1' AFTER 100 NS; END;
