10 years agoAbout VGA Output
Hello, I am working for the first time with FPGA (cyclone v soc) and i am trying to get a output from VGA Port on the monitor. I have set the resolution for 1024x768 and PLL input frequency as ...
10 years agoHi,
Clock output is from the PLL. So where are you checking this clock? Are you probing or checking in simulation? The only reason should be that either the input clock or reset has a problem. Im not seeing any other reason for not getting the clock output
