According to your code, there is no state 7. That would therefore be impossible. Also there is no state2 == 4. Also impossible. The only way this can be happening is if there is some input to the system not illustrated in the code that affects the state machine. That input may be an upset caused by the fact that you're not meeting timing. Are you meeting timing requirements?
Also, are you sure you are getting a clean reset?
May I suggest the following:
reg state;
reg state2;
reg count;
always @(posedge CLK or posedge RESET) begin
if(RESET) begin //power on reset
state <= 0;
state2 <= 0;
count <= 0;
end else begin
case (state)
0:
case (state2)
0: begin
count <= count + 1;
if(count == 2) begin
state2 <= 1;
count <= 0'
end
end
1: begin
count <= count + 1;
if(count == 6) begin
state2 <= 2;
count <= 0'
end
end
2: begin
count <= count + 1;
state2 <= 3;
count <= 0'
end
end
3: begin
count <= count + 1;
if(count) begin
state <= 1;
state2 <= 0;
count <= 0;
end
end
endcase
1: state <= 2;
2: state <= 3;
3: state <= 4;
4: state <= 5;
5: state <= 6;
6: state <= 1;
default: state <= 0;
endcase
end
end
