GMA
6 years ago275024 : width mismatch in ports
Hey all, I'm trying to implement ALTMULT_COMPLEX for complex numbers, However, when I came to implement the circuit, it shows that all input sizes are mismatch. Can you please help with that? an im...
CheepinC_altera
6 years agoHi,
Just wonder if you have had a chance to try the following:
- In your schematic, delete all the wires, pins and the altmult_complex instance
- Launch the Megawizard for the altmult_complex IP in your design and regenerate the HDL and BSF
- Add the new BSF into schematic
- Right-click on the instance -> Generate Pins. This should auto-generate the input/output pins with the corresponding width
- Run the compilation again to see if issue still persist
If issue still persist, please help to attach your test design QAR so that I can further look into it. Thank you very much.
