1G/10Gb Ethernet FPGA IP uses XGMII instead of GMII in 1Gb mode
Hi Dimistry,
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
Hi, Zying,
Q1. My question was: I see ingoing packets (LLDP) on RX on 1G/10Gbe and 10GBASE-KR PHY IP.
I see them on XGMII_RX_DATA[7:0] although I would have expected them on gmii_rx_data since the speed 1Gb is set.
Your answer: Received data may be seen on XGMII port, but it should be ignored while in 1GbE mode
If I will ignore the data on the XGMII port and I will not get any data on GMII port I will be in situation when I can't use 1G/10Gbe and 10GBASE-KR PHY Core IP. I don't understand how I can use your answer, sorry.
Q3. I am ready to use GMII interface, but I don't understand how to follow your recommendation, if the IP CORE itself uses XGMII in not documented mode. Could you provide more concrete recommendation what I need to change in CORE configuration to use GMII interface, please?
Best regards, Dmitry.
