17 years ago
.JIC file Generation
Hi all,
I wish to generate JIC file with NIOS firmware + Logic to configure EPCS and using command line, so I did a script to do this.
1) Convert SOF to Flash
sof2flash --epcs --input=$sof --output=hw.flash --quiet
2) Convert ELF to Flash
elf2flash --epcs --after=hw.flash --input=$elf --output=sw.flash
3) Concatenate
cp hw.flash hw_sw.flash
cat sw.flash >> hw_sw.flash
4) Create HexFile
nios2-elf-objcopy --input-target srec --output-target ihex hw_sw.flash $hex
So, after I need to use Quartus->File->Convert Programming Files... to generate JIC using EP3C25 Device, EPCS128 (I'm using Spansion 128Mbit) and after Programmer to download.
I search by quartus_cpf in command_line reference, but I didn't find any references to convert hex to jic, only sof.
Anybody can help with other way to create JIC (its usefull to send file to production line) or
say where I'm misunderstanding :) ?
Thx,
Veiga
Quartus 8.0
    I use that Quartus version as well.
    Do you see the "Generated .jic file with date and time" message in Quartus when you run assembler on Quartus ?
    ok, I don't know how but that code works :)
    here is what i think might have worked:
    1) Closed Quartus II
    2) Deleted all the database folders.
    3) Reopened the project and compiled it.
    Thanks @ amilcar for helping out
