19 years agoWhy linux not run until connected to terminal
My custom linux doesn,t run until connected to terminal.Why
I tested a small program "hello.c"(which lets leds flashing),and after some operation,I copy "hello.exe" to linux file"/bin/".And add "/bin/hello" to /etc/rc. If I login terminal without do anything ,the leds flashing.But if I just turn on the power and press reset,the led doesn't flash until connected terminal.Why,So I doubt if the linux is real running .Maybe I didn't set some parament or I have to do something to let linux run automatically. thanks, Best wishs TommyCP.2 Replies
You use JTAG-UART, right?
That's normal operation for JTAG-UART. Program execution is stopped when the UART's buffer is full. I don't know if you can change this bahaviour. JTAG-UART is mostly used for debugging purposes where you don't want to miss a message. I switched to a 'normal' RS232 UART. For this you need to activate Altera UART support and console on serial UART support in the kernel configuration. - Altera_Forum
popdog,
thanks,After I have changed Kernel config,and get off JTAG UART.Then It can automatically run. best wishs, TommyCP
