19 years agoWhy linux not run until connected to terminal
My custom linux doesn,t run until connected to terminal.Why I tested a small program "hello.c"(which lets leds flashing),and after some operation,I copy "hello.exe" to linux file"/bin/".And ad...
19 years agoYou use JTAG-UART, right?
That's normal operation for JTAG-UART. Program execution is stopped when the UART's buffer is full. I don't know if you can change this bahaviour. JTAG-UART is mostly used for debugging purposes where you don't want to miss a message. I switched to a 'normal' RS232 UART. For this you need to activate Altera UART support and console on serial UART support in the kernel configuration.
