20 years agowhy i can't find "new project => Microtronix NIOS"
I had installed the NIOS II Linux Distribution, but when I finished it, I found that I can't find the "new project => Microtronix NIOS II" in the NIOS II IED. Who can tell me the reason? Thanks~
--- Quote Start --- originally posted by rainhawk@Jun 28 2006, 07:19 PM i had installed the nios ii linux distribution, but when i finished it, i found that i can't find the "new project => microtronix nios ii" in the nios ii ied. who can tell me the reason? thanks~<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16468)
--- quote end ---
--- Quote End --- You'd better work on Linux and follow the nios wiki, step 1-3. http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux)
You can search in the forum ,I had solved the problem according to the method, but I gorget how to do!
--- Quote Start --- originally posted by hippo+jun 29 2006, 09:43 am--><div class='quotetop'>quote (hippo @ jun 29 2006, 09:43 am)</div>--- quote start ---
<!--quotebegin-rainhawk@Jun 28 2006, 07:19 PM i had installed the nios ii linux distribution, but when i finished it, i found that i can't find the "new project => microtronix nios ii" in the nios ii ied. who can tell me the reason? thanks~
--- quote end ---
--- Quote End --- You'd better work on Linux and follow the nios wiki, step 1-3. http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux) <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16493)</div> [/b] --- Quote End --- why? Is there something wrong with this method?
--- Quote Start --- originally posted by rainhawk+jun 29 2006, 02:18 pm--><div class='quotetop'>quote (rainhawk @ jun 29 2006, 02:18 pm)</div>--- quote start ---
<!--quotebegin-hippo@Jun 29 2006, 09:43 AM
you'd better work on linux and follow the nios wiki, step 1-3.
--- quote end ---
--- Quote End --- why? Is there something wrong with this method? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16521)</div> [/b] --- Quote End --- No, there's nothing wrong with it per se. Some things are just easier to do on linux, like adding drivers and so on. Using Windows to create a linux system can be a bit confusing. One of the bad things about using the Microtronic Linux distro is that when you create a filesystem, all the initial programs are included as .exe:s, instead of being compiled during building the project. Therefore you can't modify them or correct any problems that might occur or even try to see what the problem could be. I ran into this problem with init.exe, it just refuses to execute. (The old "init: exec failed" problem I asked earlier here.) So um, yeah, something could be wrong with the method, depending on what you're trying to do http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif . One of the bigger advantages of working on linux is that hippo will then help you http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
--- Quote Start --- originally posted by rainhawk@Jun 28 2006, 01:19 PM i had installed the nios ii linux distribution, but when i finished it, i found that i can't find the "new project => microtronix nios ii" in the nios ii ied. who can tell me the reason? thanks~<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16468)
--- quote end ---
--- Quote End --- Hi rainhawk, take a look at post 3 in http://forum.niosforum.com/forum/index.php...wtopic=3164&hl= (http://forum.niosforum.com/forum/index.php?showtopic=3164&hl=)
