19 years agoWhy I can't boot uclinux kernal in NIOSII?
I created and build a Linux kernel and filesystem project guided by the file "Linux Quick Start Guide" located in :\altera\kits\nios2_60\documents\linux.Then I secelted tools->flash programmer in IDE,and click the apply-->program flash button to download the executable file:build/vmlinux . After that I download the .sof file into the development board.When it is done,I open Nios II SDK shell and type nios2-terminal in command line. [SOPC Builder]$ nios2-terminal The boot information is as follows: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.11-uc0 (lq1@lq) (gcc version 3.4.1 (Altera Nios II 5.1 b93))# 23 Mon Aug 14 16:36:53 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 14720k/16384k RAM, 0k/0k ROM (1228k kernel code, 260k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x821208d0 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0b:04:c9 smc_probe: 50000 Khz Nios uclinux[mtd]: RAM probe address=0x1174474 size=0x0 Creating 1 MTD partitions on "RAM": 0x00000000-0x00000000 : "ROMfs" mtd: partition "ROMfs" is out of reach -- disabled uclinux[mtd]: set ROMfs to be root filesystem Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 4 MTD partitions on "Altera NDK flash (AMD)": 0x00200000-0x00600000 : "romfs/jffs2" 0x00000000-0x00200000 : "loader/kernel" 0x00600000-0x00700000 : "User configuration" 0x00700000-0x00800000 : "safe configuration" microtronix[mtd]: RAM probe address=0x200000 size=0x0 Creating 1 MTD partitions on "RAM": 0x00000000-0x00000000 : "ROMfs" mtd: partition "ROMfs" is out of reach -- disabled microtronix[mtd]: set ROMfs to be root filesystem NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 1024 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) NET: Registered protocol family 1 NET: Registered protocol family 17 end_request: I/O error, dev mtdblock0, sector 2 EXT2-fs: unable to read superblock end_request: I/O error, dev mtdblock0, sector 0 romfs: unable to read superblock Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0) Can anyone here explain the problem? Thank you very much!
