20 years agoWhy I can't boot uclinux kernal in NIOSII?
Hello, I created and build a Linux kernel and filesystem project guided by the file "Linux Quick Start Guide" located in :\altera\kits\nios2_60\documents\linux.Then I secelted tools->flash pro...
20 years agoI give the final answer:
Actually, except the kernel project created and programmed into the flash, you also need to create a root file system and program it into the flash. Please follow the steps to create the kernel project and file system project according to the "Linux Quick Start Guide". After build them successfully, open the NiosII command shell and try to program both the ext_flash.flash and romfs.flash into flash: ------------------------------------------------------------ elf2flash --base=0x00000000 --end=0x7fffff --reset=0x0 --input=vmlinux --output=ext_flash.flash --boot =$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec nios2-flash-programmer --base=0x0000 ext_flash.flash nios2-flash-programmer --base=0x0000 romfs.flash ------------------------------------------------------------- The ext_flash.flash is generated through the elf2flash command. The input file is vmlinux.bin in the "build" folder under kernel project. The romfs.flash is generated automatically after building the file system project. Please note to go to the correct directory and input the commands.
