20 years agowho can help me save my memory?
hello!
I explant my uclinux system form arm(Samsung 4510) to nios2, I need build ppp with serial port, so we need pppd, now I have a terrible problem,I find the pppd consume neraly 1.2M sdram. I can't abide it, beacause only 300kb memory is needed in the arm system. I indeed the source is same in the two plats. who can help me? Thank you for all response!18 Replies
ll
Please remove your e-mail address in previous post.
Sorry, there is no /proc//maps in nios uclinux. Please try /proc/(your ppd process id)/status and statm. - Altera_Forum
hippo,Thanks you a lot.
this the result: <div class='quotetop'>QUOTE </div> --- Quote Start --- nios flatforum[/b] --- Quote End --- :
<div class='quotetop'>QUOTE </div> --- Quote Start --- arm platform[/b] --- Quote End ---# cat /proc/74/status Name: pppd State: S (sleeping) SleepAVG: 87% Tgid: 74 Pid: 74 PPid: 64 TracerPid: 0 Uid: 0 0 0 0 Gid: 0 0 0 0 FDSize: 32 Groups: Mem: 544160 bytes Slack: 229815 bytes Shared: 0 bytes Threads: 1 SigPnd: 0000000000000000 ShdPnd: 0000000000000000 SigBlk: 0000000000000000 SigIgn: 0000000000081006 SigCgt: 0000000057816ef9 CapInh: 0000000000000000 CapPrm: 00000000fffffeff CapEff: 00000000fffffeff# cat /proc/74/statm 1065672 1065672 0 146416 0 377528 0# cat /proc/65/status Name: pppd State: S (sleeping) Tgid: 65 Pid: 65 PPid: 44 TracerPid: 0 Uid: 0 0 0 0 Gid: 0 0 0 0 FDSize: 32 Groups: Mem: 239584 bytes Slack: 1292 bytes Shared: 0 bytes SigPnd: 0000000000000000 SigBlk: 0000000000000000 SigIgn: 0000000000081006 SigCgt: 0000000057816ef9 CapInh: 0000000000000000 CapPrm: 00000000fffffeff CapEff: 00000000fffffeff# cat /proc/65/statm 113 113 0 37 0 20 0 - Altera_Forum
I think there may be problems in memory management of nios2 kernel.
How about other apps? Do they have the same problems? - Altera_Forum
Thank you hippo for all your coaching.
my god! evey apps have this problem. the mm code is a sealed book for me. In addition,I want to download my kernel image from my pc by u-boot. Do you know how can I use the u-boot's ftp service? - Altera_Forum
I don't use uboot. Scott is an expert on it.
I will look at the mm code when I have time. - Altera_Forum
Our nios2linux Cross Compiler:
1. bin files from Altera nios2 tools CD under redhat , and we copied them to proper directories. 2. build some nessary tools according "hippo_mini_nios2linux",such as elf2flt 3. modify config.arch to export CROSS_COMPILE, CC... So we guess there are some mistakes happens. Here we copy our modified config.arch
and an example of makefile under a user application############################################################################# # Settings for building user apps# ifdef UCLINUX_BUILD_USER SLIBC = -lc SLIBM = -lm SLIBNET =# -lnet#jwq:20051010 avoid route error SLIBDES = -ldes SLIBAES = -laes SLIBPCAP = -lpcap SLIBSSL = -lssl SLIBCRYPTO = -lcrypto ifeq ($(LIBCDIR),libc) SLIBCRYPT = -lcrypt_old else SLIBCRYPT = -lcrypt# //modi by zlx# reModified :jwq: 20051010 for avoiding pppd error # SLIBCRYPT = -lcrypt_old endif SLIBPTHREAD = -lpthread LIBC = $(SLIBC) LIBM = $(SLIBM) LIBNET = $(SLIBNET) LIBDES = $(SLIBDES) LIBAES = $(SLIBAES) LIBPCAP = $(SLIBPCAP) LIBSSL = $(SLIBSSL) LIBCRYPTO = $(SLIBCRYPTO) LIBPTHREAD = $(SLIBPTHREAD) LIBCRYPT = $(SLIBCRYPT) LIBGCC = -lgcc LIBIBERTY = -liberty LIBIO = -lio LIBIOSTREAM = -liostream LIBSTDCPP = -lstdc++ LDPATH = -L$(ROOTDIR)/$(LIBCDIR)/. -L$(ROOTDIR)/$(LIBCDIR)/lib -L$(ROOTDIR)/lib/libm -L$(ROOTDIR)/lib/libnet -L$(ROOTDIR)/lib/libdes -L$(ROOTDIR)/lib/libaes -L$(ROOTDIR)/lib/libpcap -L$(ROOTDIR)/lib/libcrypt_old -L$(ROOTDIR)/lib/libssl -L$(ROOTDIR)/lib/zlib INCLIBC = -I$(ROOTDIR)/$(LIBCDIR)/include INCLIBM = -I$(ROOTDIR)/lib/libm INCNET = -I$(ROOTDIR)/lib/libnet INCDES = -I$(ROOTDIR)/freeswan/libdes INCAES = -I$(ROOTDIR)/freeswan/libcrypto/libaes INCGMP = -I$(ROOTDIR)/lib/libgmp INCPCAP = -I$(ROOTDIR)/lib/libpcap INCSSL = -I$(ROOTDIR)/lib/libssl/include INCZ = -I$(ROOTDIR)/lib/zlib INCVEND = -I$(ROOTDIR)/vendors/include INCCRYPTOLD = -I$(ROOTDIR)/lib/libcrypt_old ifdef CONFIG_USER_DEBUG CFLAGS := $(if $(UOPT),$(UOPT),-O1) -g else CFLAGS := $(if $(UOPT),$(UOPT),-O2) -g -Wall -fomit-frame-pointer endif CFLAGS += $(CPUFLAGS) CFLAGS += $(VENDOR_CFLAGS) CFLAGS += -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED CFLAGS += $(INCLIBC) $(INCLIBM) $(INCCRYPTOLD) CFLAGS += -I$(ROOTDIR) CFLAGS += -fno-builtin CFLAGS += -nostartfiles ifndef DISABLE_XIP CFLAGS += -D__PIC__ -fpic -msingle-pic-base endif # # the following is needed for 2.4 # CFLAGS += -I$(ROOTDIR)/$(LINUXDIR)/include CXXFLAGS = $(CFLAGS) $(INCCXX) ifeq ($(LIBCDIR),libc) LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/libc/crt0.o else # LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/$(LIBCDIR)/lib/crt0.o # $(ROOTDIR)/lib/$(LIBCDIR)/lib/crti.o # $(ROOTDIR)/lib/$(LIBCDIR)/lib/crtn.o # jwq:20051005 LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o $(ROOTDIR)/$(LIBCDIR)/lib/crti.o $(ROOTDIR)/$(LIBCDIR)/lib/crtn.o endif ifndef DISABLE_MOVE_RODATA LDFLAGS += -Wl,-move-rodata endif LDFLAGS += $(LDPATH) LDLIBS = $(LIBC) LDLIBS_static = $(SLIBC) CXXLIBS = $(LIBSTDCPP) $(LIBIOSTREAM) $(LIBIO) $(LIBIBERTY) $(LIBC) $(LIBGCC)# ############################################################################# from nios Rules.mak in order to add right uClibc for nios only CRT0 := $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o LIBC := $(ROOTDIR)/$(LIBCDIR)/lib/libc.a LIBGCC := $(shell $(CC) -print-file-name=libgcc.a) LIBM := $(shell $(CC) -print-file-name=libm.a) LIBGCCDIR := $(dir $(LIBGCC)) LINKSCRIPT := $(UTILSDIR)/elf2flt.ld LDFLAGS := -msys-crt0=$(CRT0) -r -d -L$(ROOTDIR)/$(LIBCDIR)/lib LDLIBS := $(LIBM) $(LIBGCC) $(LIBC) # ############################################################################# from nios Rules.mak in order to add right uClibc for nios only# but now it is not used # because old arm one(CFLAHS)seems OK# CFLAGS := -nostdinc -D__linux__ -O2 -I$(ROOTDIR)/$(LINUXDIR)/include -I"d:/EDA/altera/kits/nios5/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/d/EDA/altera/kits/nios5/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall# ################## ifndef FLTFLAGS FLTFLAGS := endif export FLTFLAGS # for anyone still using it CONVERT = /bin/true UCLINUX_BUILD_SET=1 endif# ###########################################################################
there is one big difference: we find that "-elf2flt" in LDFLAGS has no effect in original Makefile, so we modified Makefile to ELF2FLT explicitly in one step according to Microtronix's did in Nios2IDE. here are messages in compling:#jwq:20051017 PROJ_NAME=chat EXEC = $(PROJ_NAME).exe OBJS = chat.o ifdef CONFIG_USER_CHAT_CHAT_NETWORK CFLAGS += -DENABLE_NETWORK_SUPPORT=1 endif all: $(EXEC)# jwq:20051017 $(PROJ_NAME).bin: $(OBJS) $(CC) $(LDFLAGS) -o $@ $(OBJS) $(LDLIBS) romfs: $(ROMFSINST) /bin/$(PROJ_NAME) clean: -rm -f $(EXEC) *.elf *.gdb *.o *.bin *.exe $(PROJ_NAME)# ############################################################################ default stack size is 4K# # jwq:20051017 FLTFLAGS:= WARNING_FLAGS := -Wall %.exe : %.flt cp -f $< $@ cp -f $@ $(PROJ_NAME)# # Make a relocatable flat file from an ELF file.# STACKSIZE is defined by individual makefiles.# %.flt : %.elf $(ELF2FLT) $(FLTFLAGS) -o $@ $< # # Make a relocatable ELF file.# %.elf : %.bin $(LD) -T $(LINKSCRIPT) -Ur -o $@ $< # ###########################################################################nios2-elf-gcc -O2 -g -Wall -fomit-frame-pointer -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/nios2linux/user_nios2linux/../uClibc_1.4.0/include -I/home/nios2linux/user_nios2linux/lib/libm -I/home/nios2linux/user_nios2linux/lib/libcrypt_old -I/home/nios2linux/user_nios2linux -fno-builtin -nostartfiles -I/home/nios2linux/user_nios2linux/../linux-2.6.x/include -c -o interface.o interface.c nios2-elf-gcc -msys-crt0=/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/crt0.o -r -d -L/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib -o loadconfig.bin loadconfig.o conf.o util.o user.o interface.o ../public_function/mysem.o ../public_function/i2c-usr.o /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a /home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/libc.a -lcrypt nios2-elf-ld -T /usr/local/bin/elf2flt.ld -Ur -o loadconfig.elf loadconfig.bin /usr/local/bin/nios2-elf-elf2flt -o loadconfig.flt loadconfig.elf cp -f loadconfig.flt loadconfig.exe cp -f loadconfig.exe loadconfig rm loadconfig.flt loadconfig.elf - Altera_Forum
Yes, mountain8848 may be right. It could be problem of your build system.
I tested inetd, ftpd and boa on my board, and there is no mm problem. I would suggest you try the guide on linux, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
