20 years agowho can help me save my memory?
hello! I explant my uclinux system form arm(Samsung 4510) to nios2, I need build ppp with serial port, so we need pppd, now I have a terrible problem,I find the pppd consume neraly 1.2M sdram...
20 years agoOur nios2linux Cross Compiler:
1. bin files from Altera nios2 tools CD under redhat , and we copied them to proper directories. 2. build some nessary tools according "hippo_mini_nios2linux",such as elf2flt 3. modify config.arch to export CROSS_COMPILE, CC... So we guess there are some mistakes happens. Here we copy our modified config.arch############################################################################# # Settings for building user apps#
ifdef UCLINUX_BUILD_USER
SLIBC = -lc
SLIBM = -lm
SLIBNET =# -lnet#jwq:20051010 avoid route error
SLIBDES = -ldes
SLIBAES = -laes
SLIBPCAP = -lpcap
SLIBSSL = -lssl
SLIBCRYPTO = -lcrypto
ifeq ($(LIBCDIR),libc)
SLIBCRYPT = -lcrypt_old
else
SLIBCRYPT = -lcrypt# //modi by zlx# reModified :jwq: 20051010 for avoiding pppd error
# SLIBCRYPT = -lcrypt_old
endif
SLIBPTHREAD = -lpthread
LIBC = $(SLIBC)
LIBM = $(SLIBM)
LIBNET = $(SLIBNET)
LIBDES = $(SLIBDES)
LIBAES = $(SLIBAES)
LIBPCAP = $(SLIBPCAP)
LIBSSL = $(SLIBSSL)
LIBCRYPTO = $(SLIBCRYPTO)
LIBPTHREAD = $(SLIBPTHREAD)
LIBCRYPT = $(SLIBCRYPT)
LIBGCC = -lgcc
LIBIBERTY = -liberty
LIBIO = -lio
LIBIOSTREAM = -liostream
LIBSTDCPP = -lstdc++
LDPATH =
-L$(ROOTDIR)/$(LIBCDIR)/.
-L$(ROOTDIR)/$(LIBCDIR)/lib
-L$(ROOTDIR)/lib/libm
-L$(ROOTDIR)/lib/libnet
-L$(ROOTDIR)/lib/libdes
-L$(ROOTDIR)/lib/libaes
-L$(ROOTDIR)/lib/libpcap
-L$(ROOTDIR)/lib/libcrypt_old
-L$(ROOTDIR)/lib/libssl
-L$(ROOTDIR)/lib/zlib
INCLIBC = -I$(ROOTDIR)/$(LIBCDIR)/include
INCLIBM = -I$(ROOTDIR)/lib/libm
INCNET = -I$(ROOTDIR)/lib/libnet
INCDES = -I$(ROOTDIR)/freeswan/libdes
INCAES = -I$(ROOTDIR)/freeswan/libcrypto/libaes
INCGMP = -I$(ROOTDIR)/lib/libgmp
INCPCAP = -I$(ROOTDIR)/lib/libpcap
INCSSL = -I$(ROOTDIR)/lib/libssl/include
INCZ = -I$(ROOTDIR)/lib/zlib
INCVEND = -I$(ROOTDIR)/vendors/include
INCCRYPTOLD = -I$(ROOTDIR)/lib/libcrypt_old
ifdef CONFIG_USER_DEBUG
CFLAGS := $(if $(UOPT),$(UOPT),-O1) -g
else
CFLAGS := $(if $(UOPT),$(UOPT),-O2) -g -Wall -fomit-frame-pointer
endif
CFLAGS += $(CPUFLAGS)
CFLAGS += $(VENDOR_CFLAGS)
CFLAGS += -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED
CFLAGS += $(INCLIBC) $(INCLIBM) $(INCCRYPTOLD)
CFLAGS += -I$(ROOTDIR)
CFLAGS += -fno-builtin
CFLAGS += -nostartfiles
ifndef DISABLE_XIP
CFLAGS += -D__PIC__ -fpic -msingle-pic-base
endif
# the following is needed for 2.4
CFLAGS += -I$(ROOTDIR)/$(LINUXDIR)/include
CXXFLAGS = $(CFLAGS) $(INCCXX)
LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/libc/crt0.o
else
# LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/$(LIBCDIR)/lib/crt0.o
# $(ROOTDIR)/lib/$(LIBCDIR)/lib/crti.o
# $(ROOTDIR)/lib/$(LIBCDIR)/lib/crtn.o
# jwq:20051005
LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o
$(ROOTDIR)/$(LIBCDIR)/lib/crti.o
$(ROOTDIR)/$(LIBCDIR)/lib/crtn.o
endif
ifndef DISABLE_MOVE_RODATA
LDFLAGS += -Wl,-move-rodata
endif
LDFLAGS += $(LDPATH)
LDLIBS = $(LIBC)
LDLIBS_static = $(SLIBC)
CXXLIBS = $(LIBSTDCPP) $(LIBIOSTREAM) $(LIBIO) $(LIBIBERTY)
$(LIBC) $(LIBGCC)# ############################################################################# from nios Rules.mak in order to add right uClibc for nios only
CRT0 := $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o
LIBC := $(ROOTDIR)/$(LIBCDIR)/lib/libc.a
LIBGCC := $(shell $(CC) -print-file-name=libgcc.a)
LIBM := $(shell $(CC) -print-file-name=libm.a)
LIBGCCDIR := $(dir $(LIBGCC))
LINKSCRIPT := $(UTILSDIR)/elf2flt.ld
LDFLAGS := -msys-crt0=$(CRT0) -r -d -L$(ROOTDIR)/$(LIBCDIR)/lib
LDLIBS := $(LIBM) $(LIBGCC) $(LIBC)
# ############################################################################# from nios Rules.mak in order to add right uClibc for nios only# but now it is not used # because old arm one(CFLAHS)seems OK# CFLAGS := -nostdinc -D__linux__ -O2 -I$(ROOTDIR)/$(LINUXDIR)/include -I"d:/EDA/altera/kits/nios5/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/d/EDA/altera/kits/nios5/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall# ##################
ifndef FLTFLAGS
FLTFLAGS :=
endif
export FLTFLAGS
# for anyone still using it
CONVERT = /bin/true
UCLINUX_BUILD_SET=1
endif# ########################################################################### and an example of makefile under a user application #jwq:20051017
PROJ_NAME=chat
EXEC = $(PROJ_NAME).exe
OBJS = chat.o
ifdef CONFIG_USER_CHAT_CHAT_NETWORK
CFLAGS += -DENABLE_NETWORK_SUPPORT=1
endif
all: $(EXEC)# jwq:20051017
$(PROJ_NAME).bin: $(OBJS)
$(CC) $(LDFLAGS) -o $@ $(OBJS) $(LDLIBS)
romfs:
$(ROMFSINST) /bin/$(PROJ_NAME)
clean:
-rm -f $(EXEC) *.elf *.gdb *.o *.bin *.exe $(PROJ_NAME)# ############################################################################ default stack size is 4K# # jwq:20051017
FLTFLAGS:=
WARNING_FLAGS := -Wall
%.exe : %.flt
cp -f $< $@
cp -f $@ $(PROJ_NAME)# # Make a relocatable flat file from an ELF file.# STACKSIZE is defined by individual makefiles.#
%.flt : %.elf
$(ELF2FLT) $(FLTFLAGS) -o $@ $<
# # Make a relocatable ELF file.#
%.elf : %.bin
$(LD) -T $(LINKSCRIPT) -Ur -o $@ $<
# ########################################################################### there is one big difference: we find that "-elf2flt" in LDFLAGS has no effect in original Makefile, so we modified Makefile to ELF2FLT explicitly in one step according to Microtronix's did in Nios2IDE. here are messages in compling: nios2-elf-gcc -O2 -g -Wall -fomit-frame-pointer -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/nios2linux/user_nios2linux/../uClibc_1.4.0/include -I/home/nios2linux/user_nios2linux/lib/libm -I/home/nios2linux/user_nios2linux/lib/libcrypt_old -I/home/nios2linux/user_nios2linux -fno-builtin -nostartfiles -I/home/nios2linux/user_nios2linux/../linux-2.6.x/include -c -o interface.o interface.c
nios2-elf-gcc -msys-crt0=/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/crt0.o -r -d -L/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib -o loadconfig.bin loadconfig.o conf.o util.o user.o interface.o ../public_function/mysem.o ../public_function/i2c-usr.o /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a /home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/libc.a -lcrypt
nios2-elf-ld -T /usr/local/bin/elf2flt.ld -Ur -o loadconfig.elf loadconfig.bin
/usr/local/bin/nios2-elf-elf2flt -o loadconfig.flt loadconfig.elf
cp -f loadconfig.flt loadconfig.exe
cp -f loadconfig.exe loadconfig
rm loadconfig.flt loadconfig.elf
