20 years ago
who can help me save my memory?
hello!
I explant my uclinux system form arm(Samsung 4510) to nios2, I need build ppp with serial port, so we need pppd, now I have a terrible problem,I find the pppd consume neraly 1.2M sdram. I can't abide it, beacause only 300kb memory is needed in the arm system.
I indeed the source is same in the two plats. who can help me?
Thank you for all response!
    Please remove your e-mail address in previous post.
    Sorry, there is no /proc//maps in nios uclinux.
    Please try /proc/(your ppd process id)/status and statm.
    hippo,Thanks you a lot.
    this the result:
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    nios flatforum[/b]
    --- Quote End ---
    # cat /proc/74/status
    State:  S (sleeping)
    SleepAVG:       87%
    Tgid:   74
    Pid:    74
    PPid:   64
    TracerPid:      0
    Uid:    0       0       0       0
    Gid:    0       0       0       0
    FDSize: 32
    Groups:
    Mem:      544160 bytes
    Slack:    229815 bytes
    Shared:        0 bytes
    Threads:        1
    SigPnd: 0000000000000000
    ShdPnd: 0000000000000000
    SigBlk: 0000000000000000
    SigIgn: 0000000000081006
    SigCgt: 0000000057816ef9
    CapInh: 0000000000000000
    CapPrm: 00000000fffffeff
    CapEff: 00000000fffffeff#  cat /proc/74/statm
    1065672 1065672 0 146416 0 377528 0
    --- Quote Start ---
    arm platform[/b]
    --- Quote End ---
    # cat /proc/65/status
    State:  S (sleeping)
    Tgid:   65
    Pid:    65
    PPid:   44
    TracerPid:      0
    Uid:    0       0       0       0
    Gid:    0       0       0       0
    FDSize: 32
    Groups:
    Mem:      239584 bytes
    Slack:      1292 bytes
    Shared:        0 bytes
    CapEff: 00000000fffffeff#  cat /proc/65/statm
    113 113 0 37 0 20 0
    I think there may be problems in memory management of nios2 kernel.
    How about other apps? Do they have the same problems?
    Thank you hippo for all your coaching.
    my god! evey apps have this problem. the mm code is a sealed book for me.
    In addition,I want to download my kernel image from my pc by u-boot.
    Do you know how can I use the u-boot&#39;s ftp service?
    I don&#39;t use uboot. Scott is an expert on it.
    I will look at the mm code when I have time.
    Our nios2linux Cross Compiler:
    1. bin files from Altera nios2 tools CD under redhat , and we copied them to proper directories.
    2. build some nessary tools according "hippo_mini_nios2linux",such as elf2flt
    3. modify config.arch to export CROSS_COMPILE, CC...
    So we guess there are some mistakes happens.
    Here we copy our modified config.arch
    ############################################################################# #  Settings for building user apps#
    ifdef UCLINUX_BUILD_USER
        SLIBC        = -lc
        SLIBM        = -lm
        SLIBNET      =# -lnet#jwq:20051010 avoid route error
        SLIBDES      = -ldes
        SLIBAES      = -laes
        SLIBPCAP     = -lpcap
        SLIBSSL      = -lssl
        SLIBCRYPTO   = -lcrypto
      ifeq ($(LIBCDIR),libc)
        SLIBCRYPT    = -lcrypt_old
      else
        SLIBCRYPT    = -lcrypt# //modi by zlx# reModified :jwq: 20051010 for avoiding pppd error
       # SLIBCRYPT    = -lcrypt_old
      endif
        SLIBPTHREAD  = -lpthread
        LIBC        = $(SLIBC)
        LIBM        = $(SLIBM)
        LIBNET      = $(SLIBNET)
        LIBDES      = $(SLIBDES)
        LIBAES      = $(SLIBAES)
        LIBPCAP     = $(SLIBPCAP)
        LIBSSL      = $(SLIBSSL)
        LIBCRYPTO   = $(SLIBCRYPTO)
        LIBPTHREAD  = $(SLIBPTHREAD)
        LIBCRYPT    = $(SLIBCRYPT)
        LIBGCC      = -lgcc
        LIBIBERTY   = -liberty
        LIBIO       = -lio
        LIBIOSTREAM = -liostream
        LIBSTDCPP   = -lstdc++
        LDPATH =
          -L$(ROOTDIR)/$(LIBCDIR)/.
          -L$(ROOTDIR)/$(LIBCDIR)/lib
          -L$(ROOTDIR)/lib/libm
          -L$(ROOTDIR)/lib/libnet
          -L$(ROOTDIR)/lib/libdes
          -L$(ROOTDIR)/lib/libaes
          -L$(ROOTDIR)/lib/libpcap
          -L$(ROOTDIR)/lib/libcrypt_old
          -L$(ROOTDIR)/lib/libssl
          -L$(ROOTDIR)/lib/zlib
        INCLIBC = -I$(ROOTDIR)/$(LIBCDIR)/include
        INCLIBM = -I$(ROOTDIR)/lib/libm
        INCNET  = -I$(ROOTDIR)/lib/libnet
        INCDES  = -I$(ROOTDIR)/freeswan/libdes
        INCAES  = -I$(ROOTDIR)/freeswan/libcrypto/libaes
        INCGMP  = -I$(ROOTDIR)/lib/libgmp
        INCPCAP = -I$(ROOTDIR)/lib/libpcap
        INCSSL  = -I$(ROOTDIR)/lib/libssl/include
        INCZ    = -I$(ROOTDIR)/lib/zlib
        INCVEND = -I$(ROOTDIR)/vendors/include
        INCCRYPTOLD = -I$(ROOTDIR)/lib/libcrypt_old
      ifdef CONFIG_USER_DEBUG
        CFLAGS  :=  $(if $(UOPT),$(UOPT),-O1) -g
      else
        CFLAGS  :=  $(if $(UOPT),$(UOPT),-O2) -g -Wall -fomit-frame-pointer
      endif
        CFLAGS  += $(CPUFLAGS)
        CFLAGS  += $(VENDOR_CFLAGS)
        CFLAGS  += -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED
        CFLAGS  += $(INCLIBC) $(INCLIBM) $(INCCRYPTOLD)
        CFLAGS  += -I$(ROOTDIR)
        CFLAGS  += -fno-builtin
        CFLAGS  += -nostartfiles
      ifndef DISABLE_XIP
        CFLAGS  += -D__PIC__ -fpic -msingle-pic-base
      endif
       #  the following is needed for 2.4
        CFLAGS  += -I$(ROOTDIR)/$(LINUXDIR)/include
        CXXFLAGS = $(CFLAGS) $(INCCXX)
        LDFLAGS  = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/libc/crt0.o
      else
       # LDFLAGS  = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/$(LIBCDIR)/lib/crt0.o
       #     $(ROOTDIR)/lib/$(LIBCDIR)/lib/crti.o
       #     $(ROOTDIR)/lib/$(LIBCDIR)/lib/crtn.o
       # jwq:20051005
        LDFLAGS  = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o
        $(ROOTDIR)/$(LIBCDIR)/lib/crti.o
        $(ROOTDIR)/$(LIBCDIR)/lib/crtn.o
      endif
      ifndef DISABLE_MOVE_RODATA
          LDFLAGS += -Wl,-move-rodata
      endif
        LDFLAGS += $(LDPATH)
        LDLIBS         = $(LIBC)
        LDLIBS_static  = $(SLIBC)
        CXXLIBS        = $(LIBSTDCPP) $(LIBIOSTREAM) $(LIBIO) $(LIBIBERTY)
          $(LIBC) $(LIBGCC)# #############################################################################  from nios Rules.mak in order to add right uClibc for nios only
    CRT0  := $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o
    LIBC  := $(ROOTDIR)/$(LIBCDIR)/lib/libc.a
    LIBGCC  := $(shell $(CC) -print-file-name=libgcc.a)
    LIBM     := $(shell $(CC) -print-file-name=libm.a)
    LIBGCCDIR   := $(dir $(LIBGCC))
    LINKSCRIPT  := $(UTILSDIR)/elf2flt.ld
    LDFLAGS   := -msys-crt0=$(CRT0) -r -d -L$(ROOTDIR)/$(LIBCDIR)/lib
    LDLIBS    := $(LIBM) $(LIBGCC) $(LIBC)
    # #############################################################################  from nios Rules.mak in order to add right uClibc for nios only#  but now it is not used #  because old arm one(CFLAHS)seems OK# CFLAGS := -nostdinc -D__linux__ -O2 -I$(ROOTDIR)/$(LINUXDIR)/include -I"d:/EDA/altera/kits/nios5/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/d/EDA/altera/kits/nios5/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx  -Wall# ##################
      ifndef FLTFLAGS
        FLTFLAGS :=
      endif
        export FLTFLAGS
       #  for anyone still using it
        CONVERT = /bin/true
        UCLINUX_BUILD_SET=1
    endif# ###########################################################################
    and an example of makefile under a user application
    #jwq:20051017
    PROJ_NAME=chat
    EXEC = $(PROJ_NAME).exe
    OBJS = chat.o
    ifdef CONFIG_USER_CHAT_CHAT_NETWORK
    CFLAGS += -DENABLE_NETWORK_SUPPORT=1
    endif
    all: $(EXEC)# jwq:20051017
    $(PROJ_NAME).bin: $(OBJS)
        $(CC) $(LDFLAGS) -o $@ $(OBJS) $(LDLIBS)
    romfs:
        $(ROMFSINST) /bin/$(PROJ_NAME)
    clean:
        -rm -f $(EXEC) *.elf *.gdb *.o *.bin *.exe $(PROJ_NAME)# ############################################################################  default stack size is 4K# # jwq:20051017
    FLTFLAGS:=
    WARNING_FLAGS := -Wall
    %.exe : %.flt
        cp -f $< $@
        cp -f $@ $(PROJ_NAME)# #  Make a relocatable flat file from an ELF file.#  STACKSIZE is defined by individual makefiles.#
    %.flt : %.elf
        $(ELF2FLT) $(FLTFLAGS) -o $@ $<
    # #  Make a relocatable ELF file.#
    %.elf : %.bin
        $(LD) -T $(LINKSCRIPT) -Ur -o $@ $<
    there is one big difference:
    we find that "-elf2flt" in LDFLAGS has no effect in original Makefile, so we modified Makefile to ELF2FLT explicitly in one step according to Microtronix&#39;s did in Nios2IDE.
    here are messages in compling:
    nios2-elf-gcc  -O2 -g -Wall -fomit-frame-pointer   -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/nios2linux/user_nios2linux/../uClibc_1.4.0/include -I/home/nios2linux/user_nios2linux/lib/libm -I/home/nios2linux/user_nios2linux/lib/libcrypt_old -I/home/nios2linux/user_nios2linux -fno-builtin -nostartfiles -I/home/nios2linux/user_nios2linux/../linux-2.6.x/include   -c -o interface.o interface.c
    nios2-elf-gcc  -msys-crt0=/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/crt0.o -r -d -L/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib -o loadconfig.bin loadconfig.o conf.o util.o user.o interface.o ../public_function/mysem.o ../public_function/i2c-usr.o /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a /home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/libc.a -lcrypt
    nios2-elf-ld -T /usr/local/bin/elf2flt.ld -Ur -o loadconfig.elf loadconfig.bin
    /usr/local/bin/nios2-elf-elf2flt  -o loadconfig.flt loadconfig.elf
    cp -f loadconfig.flt loadconfig.exe
    cp -f loadconfig.exe loadconfig
    rm loadconfig.flt loadconfig.elf
