22 years ago
What's wrong with my programm?
I have write a programme to initialize the lcd16207,but it couldn&#39;t work correctly. The code is:# include <unistd.h># include <stdlib.h># include <stdio.h>
//#include "lcd_16207.h"
/* Commands which can be written to the COMMAND register */
enum /* Write to character RAM */
LCD_CMD_WRITE_DATA = 0x80
/* Bits 6:0 hold character RAM address */
enum /* Write to character generator RAM */
LCD_CMD_WRITE_CGR = 0x40
/* Bits 5:0 hold character generator RAM address */
enum /* Function Set command */
LCD_CMD_FUNCTION_SET = 0x20,
LCD_CMD_8BIT = 0x10,
LCD_CMD_TWO_LINE = 0x08,
LCD_CMD_BIGFONT = 0x04
enum /* Shift command */
LCD_CMD_SHIFT = 0x10,
LCD_CMD_SHIFT_DISPLAY = 0x08,
LCD_CMD_SHIFT_RIGHT = 0x04
enum /* On/Off command */
LCD_CMD_ONOFF = 0x08,
LCD_CMD_ENABLE_DISP = 0x04,
LCD_CMD_ENABLE_CURSOR = 0x02,
LCD_CMD_ENABLE_BLINK = 0x01
enum /* Entry Mode command */
LCD_CMD_MODES = 0x04,
LCD_CMD_MODE_INC = 0x02,
LCD_CMD_MODE_SHIFT = 0x01
enum /* Home command */
LCD_CMD_HOME = 0x02
enum /* Clear command */
LCD_CMD_CLEAR = 0x01
};# define na_lcd_pio_command ((volatile int *) 0x80920850)# define na_lcd_pio_status ((volatile int *) 0x80920851)# define na_lcd_pio_wr_data ((volatile int *) 0x80920852)# define na_lcd_pio_rd_data ((volatile int *) 0x80920853)
# define PIO_LCD_IO_COMMAND (*na_lcd_pio_command)# define PIO_LCD_IO_STATUS (*na_lcd_pio_status)# define PIO_LCD_IO_WR_DATA (*na_lcd_pio_wr_data)# define PIO_LCD_IO_RD_DATA (*na_lcd_pio_rd_data)
void delay(int para)//delay for 0.2*para ms
int i=0,j=0;
for(i=0;i<para;i++)
for(j=0;j<10000;j++)
int main()
delay(75);
PIO_LCD_IO_COMMAND=LCD_CMD_FUNCTION_SET | LCD_CMD_8BIT;
delay(21);
delay(1);
PIO_LCD_IO_COMMAND=LCD_CMD_FUNCTION_SET | LCD_CMD_8BIT | LCD_CMD_TWO_LINE;
PIO_LCD_IO_COMMAND=LCD_CMD_ONOFF;
PIO_LCD_IO_COMMAND=LCD_CMD_CLEAR;
PIO_LCD_IO_COMMAND=LCD_CMD_MODES | LCD_CMD_MODE_INC;
PIO_LCD_IO_COMMAND=LCD_CMD_ONOFF | LCD_CMD_ENABLE_DISP;
delay(1000);
return 0;
My operation system is uClinux,and the board is cyclone,what&#39;s wrong with me? help!
