22 years agoWhat's wrong with my programm?
I have write a programme to initialize the lcd16207,but it couldn't work correctly. The code is:# include <unistd.h># include <stdlib.h># include <stdio.h> //#include "lcd_16207.h" /* Comman...
22 years agoWhy are you bothering with initialization?
With Nios II (and the HAL), you should be able to open the device and use fprintf to print to it, like so: char *your_msg = "All work and No play..."; /* Get a file handle */ /* NOTE: Your name will match the name you chose from SOPC Builder... the example, below, matches the name in the standard and full_featured designs*/ FILE *lcd = fopen( "/dev/lcd_display", "w"); /* Using the lcd file handle, "print" to the LCD Device */ fprintf(lcd, "%s\n", your_msg); The syntax may not be *exactly* like this, but this is what I recall from several of the software "templates". For some reason Count Binary comes to mind.... Cheers, - slacker
