13 years agoWhat is DDR2 Clock Frequency Setting (Affect Niche Stack and VIC functionality)...?
Dear Friend's
I am using Altera ESDK-Cyclone-III board My Application is to collect data from Synchronous port (1 Mbps) and forward it to Ethernet Port (TCP packets) & for testing i am using RS232 Port. but both ports and Vectored Interrupt Controller (VIC) won't work at time 1. Setting ddr2_bot clock from 165 to 150 mhz Results 1.1 Quartus: Critical Warning: Timing not met 1.2 Ping Stop Responding 1.3 VIC receive all the interrupt 2. Setting ddr2_bot clock from 150 to 125 mhz Results 2.1. Quartus: Critical warning removed: Timing not met 2.2. Ping Stop Responding 2.3. VIC Collect all the Interrupt 3. Setting ddr2_bot clock back to 165 mh Results 3.1 Quartus: Critical Warning: Timing not met 3.2 Ping Responding 3.3 VIC not able to receive all the interrupt 3.4 after interrupt activity ping also stop responding Regards Kaushal1 Reply
