20 years agoVGA support in uclinux
hi all,
I am trying to enable VGA support in uclinux (1.4 rel). In make menuconfig -> Device Drivers -> Graphics support, I found [] Support for frame buffer devices if I enalbe this support further it gives me 4-5 options Is that enough to enable VGA support in uclinux. I searched for Console display driver support -> but I could not find it. If any one has tried it before then pls suggest proper procedure. thanks Ankur5 Replies
Hi Ankur,
How do you connect the VGA? There is no avalon bus VGA support in kernel yet. Maybe you can help to port it. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif - Altera_Forum
--- Quote Start --- originally posted by hippo@Jun 2 2006, 06:27 AM hi ankur,how do you connect the vga?
there is no avalon bus vga support in kernel yet.
maybe you can help to port it. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15798)
--- quote end ---
--- Quote End --- hi hippo and all, I have lancelot VGA controller board, which I can connect to stratix 2s60 dev board 40 pin prototype connector. <div class='quotetop'>QUOTE </div> --- Quote Start --- There is no avalon bus VGA support in "kernel" yet.[/b] --- Quote End --- I can't understand this statement, I mean if I put a VGA IP core (third party) in hw config (sopc builder) and VGA core handles frame buffer mechanism then last thing is kernel support required. Ok I agree that I have to either port or write a new frame buffer driver. I hope my understanding is correct or pls correct it with you comments. If I am going in wrong direction then pls suggest or inform me. thanks Ankur
I don't know if the kit come with the driver for uClinux. If not, then you have to port or write a frame buffer driver.
I believe the lancelot core is Avalon compatible, so that is what he is probably using. Regarding the driver, there is no driver for it yet - on your board, do you have a separate video buffer, or is it all run from the same RAM (SDRAM, DDR?). If you don't have separate video memory, like SRAM, running linux and video at the same time will be very difficult. And as hippo mentioned, you still need a framebuffer driver..
--- Quote Start --- --- Quote Start --- I believe the lancelot core is Avalon compatible, so that is what he is probably using. Regarding the driver, there is no driver for it yet - on your board, do you have a separate video buffer, or is it all run from the same RAM (SDRAM, DDR?). If you don't have separate video memory, like SRAM, running linux and video at the same time will be very difficult. And as hippo mentioned, you still need a framebuffer driver.. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15809)</div> --- Quote End --- hi all, thanks for the interest and reply, YES, lancelot core is Avalon compatilbe, I am using the same and I agree there is need for porting frame buffer driver for same, at present I am doing the feasibility study (going through other frame buffer driver present in uclinux) to do so. The example C code given by lancelot www.fpga.nl site, looks like it runs from SDRAM. Once I finish with the study I will update all, thanks, Ankur
