20 years agoVGA support in uclinux
hi all, I am trying to enable VGA support in uclinux (1.4 rel). In make menuconfig -> Device Drivers -> Graphics support, I found [] Support for frame buffer devices if I enalbe this s...
20 years ago --- Quote Start --- originally posted by hippo@Jun 2 2006, 06:27 AM hi ankur,
how do you connect the vga?
there is no avalon bus vga support in kernel yet.
maybe you can help to port it. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15798)
--- quote end ---
--- Quote End --- hi hippo and all, I have lancelot VGA controller board, which I can connect to stratix 2s60 dev board 40 pin prototype connector. <div class='quotetop'>QUOTE </div> --- Quote Start --- There is no avalon bus VGA support in "kernel" yet.[/b] --- Quote End --- I can't understand this statement, I mean if I put a VGA IP core (third party) in hw config (sopc builder) and VGA core handles frame buffer mechanism then last thing is kernel support required. Ok I agree that I have to either port or write a new frame buffer driver. I hope my understanding is correct or pls correct it with you comments. If I am going in wrong direction then pls suggest or inform me. thanks Ankur
