21 years agoVGA controller AppNote 333
Has anyone ever tried the vga controller design from AN333? I have modified it from displaying 8-bit color pixels (using LUT) to 24-bit RGB pixels, by widening the bus to 32-bits, using 24-bits for RGB and wasting 8-bits. However, the output display is shifted by ~~140 pixels (horizontally) for every 100 lines (vertically).
Has anyone successfully come up with a 24-bit RGB color pixels VGA controller that uses avalon's streaming capabilities? Thanks for any help.1 Reply
Check your vertical and gorizontal timing parameters.
For 800*600 it should be next: // horizontal timing parameters parameter hsync_end = 80; parameter hblank_begin = 200; parameter hblank_end = 1000; parameter hline_end = 1040; // vertical timing parameters parameter vsync_end = 4; parameter vblank_begin = 26; parameter vblank_end = 626; parameter vframe_end = 629; And when you send data by dma, dmalength must be 800*600*4.
