21 years agoVGA controller AppNote 333
Has anyone ever tried the vga controller design from AN333? I have modified it from displaying 8-bit color pixels (using LUT) to 24-bit RGB pixels, by widening the bus to 32-bits, using 24-bits for R...
21 years agoCheck your vertical and gorizontal timing parameters.
For 800*600 it should be next: // horizontal timing parameters parameter hsync_end = 80; parameter hblank_begin = 200; parameter hblank_end = 1000; parameter hline_end = 1040; // vertical timing parameters parameter vsync_end = 4; parameter vblank_begin = 26; parameter vblank_end = 626; parameter vframe_end = 629; And when you send data by dma, dmalength must be 800*600*4.
