13 years agoverify failed between address 0x3000020 and 0x300988B
Hello, When I build and download my Hello World application using the 'Run Configurations' GUI menu in Eclipse, I get a 'verify failed' error. Anyone know what this indicates and how I can resolve...
13 years agoHi there,
before you can download any code to your Nios you have to configure teh FPGA first. Use the Quartus programmer to download the .sof according to your NIOS first. After that you can download the NIOS code as often as you want, unless you do a power reset. If you do have an EPCS or CFI Flash then you can download the .sof to it, after that you can directly start your NIOS programm.
