13 years agoVectored Interrupt Controller VIC Respond if i take out Ethernet Connector RJ-45
Hello Friends I am getting Continuous interrupt on nios-II, and this interrupt handle by VIC (Collected by edge_capture register-Please see attached jpeg ). whenever interrupt come i asse...
13 years ago --- Quote Start --- Hello Friends I am getting Continuous interrupt on nios-II, and this interrupt handle by VIC (Collected by edge_capture register-Please see attached jpeg ). whenever interrupt come i assert HIGH to nios-ii External pin Temp_out. but VIC not able to handle all the interrupt and stuck in between or before collecting all the interrupts (Please see attached jpeg). but if i take out ethernet port rj-45 from my ESDK-Cyclone-III board , vic collect all the interrupt. what measure should i take for vic to collect all the interrupt...? Regards Kaushal --- Quote End --- Hi, How are your settings for the VIC driver in your BSP? Are you using MicroC/OS-II ? regards
