11 years agoVariable Precision DSP in Arria V Devices
hey folks,
I am new to altera stuff. I am porting my design from xilinx devices to altera devices. In that process am facing problems with DSPs porting. I am not finding dsp in altera similar to DSP48E1 to do functions like (axb) + c. I found one document Variable Precision DSP in Arria V Devices, but not finding a way to use this in Arria v. I am using Quartus II 14.0 version(trial version). I didn't even find in Ip catalog. Can some one help me on this. Thanks in advance.15 Replies
--- Quote Start --- I gave you the code to infer them already. I suggest reading the VHDL coding guidelines for inference. http://www.altera.co.uk/literature/hb/qts/qts_qii51007.pdf --- Quote End --- hey, Thanks for info.. I synthesized following code which I found in the above document. It's inferring dsp and 17 luts for adder, 39 registers. Actually it should infer adder also inside dsp. module unsig_altmult_accum (dataout, dataa, datab, clk, aclr, clken); input [7:0] dataa, datab; input clk, aclr, clken; output reg[16:0] dataout; reg [7:0] dataa_reg, datab_reg; reg [15:0] multa_reg; wire [15:0] multa; wire [16:0] adder_out; assign multa = dataa_reg * datab_reg; assign adder_out = multa_reg + dataout; always @ (posedge clk or posedge aclr) begin if (aclr) begin dataa_reg <= 8'b0; datab_reg <= 8'b0; multa_reg <= 16'b0; dataout <= 17'b0; end else if (clken) begin dataa_reg <= dataa; datab_reg <= datab; multa_reg <= multa; dataout <= adder_out; end end endmodule - Altera_Forum
--- Quote Start --- hey, Thanks for info.. I synthesized following code which I found in the above document. It's inferring dsp and 17 luts for adder, 39 registers. Actually it should infer adder also inside dsp. --- Quote End --- No it wont. Like we said, the DSPs only have pre-multiplier adders. So you need to do any adition before the multiply to even hope that the adder goes in the DSP. - Altera_Forum
Finally I found solution. If we don't register multiplier output, it infers adder also into dsp.
with the following code. wire [35:0] mul_out = ((mul_a_in[17:0]) * (mul_b_in[17:0])); assign adder_out = $signed(add_c_in[35:0] + mul_out); it can do (36 bit + (18 x 18)). - Altera_Forum
but unless you register the adder output, you're going to get poorer fmax.
--- Quote Start --- but unless you register the adder output, you're going to get poorer fmax. --- Quote End --- hey tricky, That registering can be done in dsp itself, Even we can register inputs also once inside dsp. this is the dsp inside arria v. http://www.alteraforum.com/forum/attachment.php?attachmentid=9723&stc=1 This is the dsp inside arria V series devices.
