22 years agoUsing LAN91C111 and LWIP in 16-bit mode?
Currently I’m working with the Cyclone Development Board and the Nios II to evaluate some things for a new system. The new board will be equipped with an EPC1C12 in a 240-PQFP package. To save some IO pins the CompactFlash, the standard Flash (which stores FPGA configuration data and program data) and the Ethernet MAC/PHY (LAN91C111) will share the same address and data signals. Because the CompactFlash and the standard Flash only need a 16-bit data bus the LAN91C111 should also work in 16-bit mode. Which SW/HW changes are needed to use the LAN91C111 in 16-bit mode with the stand alone LWIP? Thank you in advance, niosIIuser7 Replies
--- Quote Start --- originally posted by niosiiuser@Jul 21 2004, 08:48 AM hello,currently i’m working with the cyclone development board and the nios ii to evaluate some things for a new system. the new board will be equipped with an epc1c12 in a 240-pqfp package. to save some io pins the compactflash, the standard flash (which stores fpga configuration data and program data) and the ethernet mac/phy (lan91c111) will share the same address and data signals. because the compactflash and the standard flash only need a 16-bit data bus the lan91c111 should also work in 16-bit mode.
which sw/hw changes are needed to use the lan91c111 in 16-bit mode with the stand alone lwip?
thank you in advance,
niosiiuser
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=521)
--- quote end ---
--- Quote End --- I dont' know what cano you do, but i find this in altera_avalon_lan91c111.c source code of lan91C111 HAL library: int alt_avalon_lan91c111_init(alt_avalon_lan91c111_if *dev) { int ret_code; if (dev->bus_width != 32) { printf("This driver doesn't support the Ethernet add on card at present\n"); ret_code = -EIO; goto exit; } ........ I hope it can help you.
I have the same problem when using Nir's Opencores MAC functions... can u pl tell me how to solve it? Raghu - Altera_Forum
It has been done several times:
http://forum.niosforum.com/forum/index.php...st=&#entry10776 (http://forum.niosforum.com/forum/index.php?showtopic=2788&pid=10776&mode=threaded&show=&st=&#entry10776) If the link does not work just search lan91c111 - Altera_Forum
--- Quote Start --- originally posted by tns1@Feb 24 2006, 12:48 PM it has been done several times:http://forum.niosforum.com/forum/index.php...st=&#entry10776 (http://forum.niosforum.com/forum/index.php?showtopic=2788&pid=10776&mode=threaded&show=&st=&#entry10776)
if the link does not work just search lan91c111
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12953)
--- quote end ---
--- Quote End --- I wish some friendly sould posted the corrected driver for the Nios II comunity. Just to avoid doing this yet another time... I would really appreciate this. It would be really great if Altera included this fixed driver in their standard installation. I know, I am just dreaming. Anyway - anybody would like to share his/her 16-bit driver for LAN91C111?
--- Quote Start --- originally posted by pszemol+mar 25 2006, 12:07 am--><div class='quotetop'>quote (pszemol @ mar 25 2006, 12:07 am)</div>--- quote start ---
<!--quotebegin-tns1@Feb 24 2006, 12:48 PM it has been done several times:
--- quote end ---
--- Quote End --- I wish some friendly sould posted the corrected driver for the Nios II comunity. Just to avoid doing this yet another time... I would really appreciate this. It would be really great if Altera included this fixed driver in their standard installation. I know, I am just dreaming. Anyway - anybody would like to share his/her 16-bit driver for LAN91C111? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=13784)</div> [/b] --- Quote End --- The driver has already been posted http://forum.niosforum.com/forum/index.php?act=st&f=15&t=466 (http://forum.niosforum.com/forum/index.php?act=st&f=15&t=466)
I've found to make the LAN91c111 really work as a 16 bit device
on the Nios2 development board, one has to modify the file "class.ptf" in the altera_avalon_lan91c111 component folder. When the 'LAN91C111 MAC/PHY On Daughtercard' option is chosen then specifically these sections matter the most: $SPW/PORT byteenablen/width = "2"; $SPW/PORT address/width = "15"; $SPW/PORT data/width = "16"; $SBI/Data_Width = "16"; $SBI/Address_Width = "15"; $CONSTANTS/CONSTANT LAN91C111_REGISTERS_OFFSET/value = "0x0300"; $CONSTANTS/CONSTANT LAN91C111_DATA_BUS_WIDTH/value = "16"; After that the posted driver works great. - Altera_Forum
i think you idea is not correct, the LAN91C111 can still work in 32-bit because the AVALON can suited it.yes or no??
