22 years agoUsing LAN91C111 and LWIP in 16-bit mode?
Hello, Currently I’m working with the Cyclone Development Board and the Nios II to evaluate some things for a new system. The new board will be equipped with an EPC1C12 in a 240-PQFP package. T...
20 years ago --- Quote Start --- originally posted by niosiiuser@Jul 21 2004, 08:48 AM hello,
currently i’m working with the cyclone development board and the nios ii to evaluate some things for a new system. the new board will be equipped with an epc1c12 in a 240-pqfp package. to save some io pins the compactflash, the standard flash (which stores fpga configuration data and program data) and the ethernet mac/phy (lan91c111) will share the same address and data signals. because the compactflash and the standard flash only need a 16-bit data bus the lan91c111 should also work in 16-bit mode.
which sw/hw changes are needed to use the lan91c111 in 16-bit mode with the stand alone lwip?
thank you in advance,
niosiiuser
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=521)
--- quote end ---
--- Quote End --- I dont' know what cano you do, but i find this in altera_avalon_lan91c111.c source code of lan91C111 HAL library: int alt_avalon_lan91c111_init(alt_avalon_lan91c111_if *dev) { int ret_code; if (dev->bus_width != 32) { printf("This driver doesn't support the Ethernet add on card at present\n"); ret_code = -EIO; goto exit; } ........ I hope it can help you.
