10 years agoUse SDRAM simultaneously with HSP and FPGA
Hi
I am using Altera DE1 Soc board. I use HPS and the master on Altera Avalon bus and SDRAM controller as slave which is connected to the SDRAM. I can read and write to the SDRAM without any problem. Now, I am wondering if I can access the SDRAM from the FPGA at the same time. If yes, can anyone tell me how to that? Best,2 Replies
This one... that SDRAM looks like in sharing mode, maybe you could do a quick test by simulate the write from fgpa and read back from hps for the same memory address for confirmation :D:D
--- Quote Start --- This one... that SDRAM looks like in sharing mode, maybe you could do a quick test by simulate the write from fgpa and read back from hps for the same memory address for confirmation :D:D --- Quote End --- Thanks for the reply. I cannot, in Qsys, either I have to connect the S1 from the SDRAM controller to HPS or I have to export it to the FPGA. So, that is where I am not sure what to do.
