10 years agoUse SDRAM simultaneously with HSP and FPGA
Hi I am using Altera DE1 Soc board. I use HPS and the master on Altera Avalon bus and SDRAM controller as slave which is connected to the SDRAM. I can read and write to the SDRAM without any probl...
10 years ago --- Quote Start --- This one... that SDRAM looks like in sharing mode, maybe you could do a quick test by simulate the write from fgpa and read back from hps for the same memory address for confirmation :D:D --- Quote End --- Thanks for the reply. I cannot, in Qsys, either I have to connect the S1 from the SDRAM controller to HPS or I have to export it to the FPGA. So, that is where I am not sure what to do.
