hi hippo
This version is so cool !
Thank you !
Why this version have more free memory can be used ?
But i can't see it for used memory info .
Thx !
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6340k/8192k RAM, 0k/0k ROM (1406k kernel code, 353k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80481120 (irq = 1) is a jtag_uart
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
Clock not ready after 20ms
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 4, io mem 0x804810d0
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 4
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
NET: Registered protocol family 2
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 228k freed (0x972000 - 0x9aa000)
Shell invoked to run file: /etc/rcusb 1-2: new full speed USB device using isp13
62-hcd and address 2
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/ (
http://www.uclinux.org/)
Execution Finished, Exiting
Sash command shell (version usb 1-2: configuration# 1 chosen from 1 choice
1.1.1)
/> scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: eUSB Model: Compact Flash Rev: 5.07
Type: Direct-Access ANSI SCSI revision: 02
SCSI device sda: 250880 512-byte hdwr sectors (128 MB)
sda: Write Protect is off
sda: assuming drive cache: write through
sda: sda1
sd 0:0:0:0: Attached scsi removable disk sda
/> free
MemTotal: 6568 kB
MemFree: 5092 kB
Buffers: 0 kB
/> cd /[/b]
--- Quote End ---
