20 years agoUpgrade sdram chip to 16MB for DE2 dev...
Hi hippo My sdram memory is 8MB that not enough free memory to run some app program on uClinux,and i want to replace it .Recently ,I already find IS42S16800B sdram chip(16MB) that match all pin...
20 years ago --- Quote Start --- originally posted by hippo@Jun 4 2006, 07:28 AM try "unset cc" ,and run "make menuconfig" again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15876)
--- quote end ---
--- Quote End --- I can"t execute "make menuconfig" comamnd on linux. Why ? <div class='quotetop'>QUOTE </div> --- Quote Start --- [faye@localhost uClinux-dist-test]$ unset CC [faye@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/faye/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' /bin/sh: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' make: *** [menuconfig] Error 2[/b] --- Quote End ---
