15 years agoUpdating e2fsprogs for ext4 support
I'm wanting to experiment with the performance capabilities of EXT4 on a Compact Flash on my Cyclone II Dev Board .
In the filesystems I have enabled EXT4 and I've got my Compact Flash mounted as EXT4. When I power up and I try and do a: e2fsck -pv /dev/sda1 It tells me my e2fsck does not support EXT4 and to update. How do I do that ? I see the latest version of e2fsprogs is 1.41.12 and the current uClinux-dist has 1.40.9 and e2fsprogs-lib-1.41.0. Thanks in advance.6 Replies
You can update an app or library in uClinux-dist something like this:
Find if there are any patches/differences in the uClinux-dist version to the same version from upstream. Put the new version next to the old version in the directory (i.e. uClinux-dist/user/appname). Apply any patches to the new version. Modify the top level Makefile for that app to use the new version. Hope that it just works. ;) - Altera_Forum
Thanks - Now could you clarify how to:
Find if there are any patches/differences in the uClinux-dist version to the same version from upstream. I'm pretty sure I'm able to do the rest. I've been trying to do a ./update yesterday and today and I keep getting sopc.et.ntust.edu.tw[0: 140.118.20.145]: errno=Connection timed out fatal: unable to connect a socket (Connection timed out) for everything ... - Altera_Forum
--- Quote Start --- Thanks - Now could you clarify how to: Find if there are any patches/differences in the uClinux-dist version to the same version from upstream. --- Quote End --- I've just downloaded the upstream version and did a diff. I suppose the information should be in the git history, but that depends on how the code was imported. For example: git log -p user/portmap/portmap_6.0 shows 2 patches: the initial import of version 6.0, and the uClinux-dist patch that added the NOMMU macro and broke it. - Altera_Forum
I'm getting an error when I "make"
************************************** make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl' make[5]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl' make[5]: Nothing to be done for `install-shlibs'. make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl' making install in e2fsck make[5]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/e2fsck' CC ../../e2fsprogs-1.41.12/e2fsck/util.c MKINSTALLDIRS //sbin /usr/share/man/man8 GEN /home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox/Makefile Using /home/janet/nios2-linux/uClinux-dist/user/busybox/busybox as source for busybox LD e2fsck e2fsck.elf2flt(.text+0x12afc): In function `init_resource_track': ../../e2fsprogs-1.41.12/e2fsck/util.c:293: undefined reference to `sbrk' e2fsck.elf2flt(.text+0x12c34): In function `print_resource_track': ../../e2fsprogs-1.41.12/e2fsck/util.c:358: undefined reference to `sbrk' collect2: ld returned 1 exit status make[5]: *** [e2fsck] Error 1 make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/e2fsck' make[4]: *** [install-progs-recursive] Error 1 make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12' make[3]: *** [all] Error 2 make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs' make[2]: *** [e2fsprogs] Error 2 make[2]: *** Waiting for unfinished jobs.... make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox' make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox' make[2]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user' make: *** [subdirs] Error 1 [janet@localhost uClinux-dist]$ *********************************************** How can I get "sbrk" linked correctly ? Thanks in advance - Altera_Forum
The e2fsprogs-1.41.12 is available in trunk branch which we used for mmu,
Just update the makefile to include fsck.ext4 etc. uClinux-dist/user/e2fsprogs/Makefile - Altera_Forum
I still have the error. Here are the steps I took
From uClinux-dist directory e2fsprogs-1.41.12 1. make clean (to start fresh) 2. put the new folder -- e2fsprogs-1.41.12 under user/e2fsprogs 3. modified the Makefile as instructed. 4. make menuconfig - defaulting everything 5. make vendor_hwselect SYSPTF=my.ptf 6. make ALL WORKS 7. make menuconfig - (selected to customize Application/Library settings) under Filesystem Application - EXT2 - selected "e2fsck" 8. make AND I get the same error posted earlier. So what am I missing ? Thanks in advance
