15 years agoUpdating e2fsprogs for ext4 support
I'm wanting to experiment with the performance capabilities of EXT4 on a Compact Flash on my Cyclone II Dev Board . In the filesystems I have enabled EXT4 and I've got my Compact Flash mounted ...
15 years agoI'm getting an error when I "make"
************************************** make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl' make[5]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl' make[5]: Nothing to be done for `install-shlibs'. make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/intl' making install in e2fsck make[5]: Entering directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/e2fsck' CC ../../e2fsprogs-1.41.12/e2fsck/util.c MKINSTALLDIRS //sbin /usr/share/man/man8 GEN /home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox/Makefile Using /home/janet/nios2-linux/uClinux-dist/user/busybox/busybox as source for busybox LD e2fsck e2fsck.elf2flt(.text+0x12afc): In function `init_resource_track': ../../e2fsprogs-1.41.12/e2fsck/util.c:293: undefined reference to `sbrk' e2fsck.elf2flt(.text+0x12c34): In function `print_resource_track': ../../e2fsprogs-1.41.12/e2fsck/util.c:358: undefined reference to `sbrk' collect2: ld returned 1 exit status make[5]: *** [e2fsck] Error 1 make[5]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12/e2fsck' make[4]: *** [install-progs-recursive] Error 1 make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs/build-e2fsprogs-1.41.12' make[3]: *** [all] Error 2 make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/e2fsprogs' make[2]: *** [e2fsprogs] Error 2 make[2]: *** Waiting for unfinished jobs.... make[4]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox/build-busybox' make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/busybox' make[2]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user' make: *** [subdirs] Error 1 [janet@localhost uClinux-dist]$ *********************************************** How can I get "sbrk" linked correctly ? Thanks in advance
