16 years agoUpdating application in EPCS via UART
My customer requires the ability to download updated application code via UART. We use the JTAG tools to store the FPGA configuration data and app code in EPCS flash memory before shipping. T...
16 years ago// 3) If we arrive at this point we have assume that there is valid-looking
// configuration data. Extract its length. If the extracted length is all // "1", assume that we're looking at erased flash. In this case, we have // no other recourse than to hang. // // The configuration bitstream length is encoded in a particular bit of a // run of bytes. Total length field is 32 bits, which goes from CB Option // bits 86..55 corresponding to bit[3] of byte[39] to byte[33] (for the most // significant 7 bits) followed by the range of bits made up of bit[2] of // bytes[72..48]. // // The note about EPCS bit reversal still applies (so we're really looking // at bits[4] and [5], respectively. My best guess is to grab a single bit from 32 different bytes to build the 32 bit length value. The first 7 bits are found in bit 4 of byte 33 thru 39. The remaining 25 bits are found in bit 5 of bytes 48 thru 72. Astoundingly complex... Dan
