Toanatron
6 months agoUnable to transmit out of 16550 Compatible UART
Hi I am following the example of the 16550 Compatible UART in the Embedded peripherals IP User Guide and using the provided code I am not seeing any data in the loopback configuration. Software i...
KianHinT_altera
6 months agoHi Toanatron ,
Just to clarify, you're testing UART loopback between Uart 0 and Uart 1 as the example below
Could you also let me know what FPGA platform you're usng?
Kian
KianHinT_altera
6 months agoForgot to mentioned, did you try running the c code example which configures the uart ports and test the UART0<->UART1
kian
