21 years agoUnable to open flash-device
Hi lads , does any body know haw to solve this one :
<div class='quotetop'>QUOTE </div> --- Quote Start --- 10 juin 2005 16:59:16 - (INFO) nios2-flash-programmer: Launching Quartus Programmer to download: C:/altera/kits/nios2/components/ZC005/system/ZC005.sof 10 juin 2005 16:59:23 - (GRAVE) nios2-flash-programmer: Error opening target hardware 10 juin 2005 16:59:23 - (GRAVE) nios2-flash-programmer: Unable to open flash-device after successfully communicating with target. It is likely that you are using a flash-programming FPGA design which was not created for your target board.[/b] --- Quote End --- - I can program my EPCS all right with the JTAG, so my JTAG_UART is fine. - I am using a 1 MBytes 29LV081B-70 Flash with Thold = Tsetup = 40 ns and Twait = 160 ns - I have try to increased my PLL clock from 50 MHz to 70 MHz, without success. does anybody have any ideas ???. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif .3 Replies
gregoryw,
This message means that programming is failing in the first step, downloading the programming .sof to the board. This programming operation is downloading to the FPGA -- if you have a different JTAG header on your board that you were using for the EPCS chip independently, you might double check to see that the cable is correct. - Altera_Forum
I can program the EPCS with the JTAG using the flash programmer , and I can also use it to debug on the IDE console when I am using OnChipMemory, so I think the JTAG is OK. Any others ideas ?.
greg. - Altera_Forum
An update : when I run the memtest from the SRAM and I try to test my flash, I get the following message :
<div class='quotetop'>QUOTE </div> --- Quote Start --- ---------------------------------- Memory Test Main Menu ---------------------------------- a: Test RAM b: Test Flash q: Exit ---------------------------------- Select Choice (a-http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif : [Followed by <enter>]b Enter the name of the CFI flash device to be opened, or just press <enter> to open "/dev/ext_flash") > -ERROR: Could not open /dev/ext_flash[/b] --- Quote End --- it seems that my AMD flash can not be reconized. So I m wondering if there is a list somewhere in the ALTERA sources that tells how to reconize if a flash is an AMD an INTEL or something else ???. heeeeeelp http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
