21 years agoUnable to open flash-device
Hi lads , does any body know haw to solve this one : <div class='quotetop'>QUOTE </div> --- Quote Start --- 10 juin 2005 16:59:16 - (INFO) nios2-flash-programmer: Launching Quartus ...
21 years agogregoryw,
This message means that programming is failing in the first step, downloading the programming .sof to the board. This programming operation is downloading to the FPGA -- if you have a different JTAG header on your board that you were using for the EPCS chip independently, you might double check to see that the cable is correct.
