19 years agouClinux to personal NiosII board
hi,
I saw the new release of uClinux for Nios on your site: http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist) And I try to port the uCLinux on my board according to the site, but failed. The board is design by myself, not the Altera series board. The hardware source now is: EP1C12(FPGA), SDRAM(8Mbytes, 16bits data line), Flash(2Mbytes, 8bits data line), SRAM(512Kbtyes, 16bits data line), LED, button, UART. And I will expand LCD and key-button on it, have no Net peripheral. The question is can I port uClinux on my board? I try method your site provide, I think I should customize kernel by use "make menuconfig", but don't konw how to, cause I can't enter the custom menu by the site method. So I can't turn of the Net support and choose a series device(uart or jtag uart). And when I use "make" to creat image, there is some errors as follow: ----------------------------------------- include/linux/seccomp.h: In function `secure_computing': include/linux/seccomp.h:18: error: `TIF_SECCOMP' undeclared (first use in this function) include/linux/seccomp.h:18: error: (Each undeclared identifier is reported only once include/linux/seccomp.h:18: error: for each function it appears in.) include/linux/seccomp.h: In function `has_secure_computing': include/linux/seccomp.h:24: error: `TIF_SECCOMP' undeclared (first use in this function) In file included from arch/nios2nommu/kernel/asm-offsets.c:12: include/linux/sched.h: At top level: include/linux/sched.h:311: error: field `mmap_sem' has incomplete type make[2]: *** [arch/nios2nommu/kernel/asm-offsets.s] 错误 1 make[1]: *** [prepare0] 错误 2 make[1]: Leaving directory `/home/gaobing/download/uClinux-dist/linux-2.6.x' make: *** [linux] 错误 1 [gaobing@tu194011 uClinux-dist]$ ------------------------------------------- And I can't run zImage on the Nios SDK Shell. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Need your help, ths! giantice 18th Jan, 20079 Replies
Which Linux distro do you use?
Please install uClinux-dist again at your home dir, not under download dir. Please do it over again. You should not need costumize kerenl at the biginnig. Try "NON_SMP_BUILD=1 make" and post the last message. Please list your steps, if you still have problems. - Altera_Forum
TO_BE_DONE
You are very close to finish.
You need to install bison package for ftpd, or you can disable ftpd. - Altera_Forum
Hi hippo,
Thanks! Is it the ftpd problem, so I can't build up the filesystem success?I have tried on the DE2 board, the problem was same. How to intall bison package for ftpd? I needn't net for my board, and how can I disable ftpd? Does it in "make menuconfig" ---> "[] customize Kernel Settings" (or "Customize Vendor/User settings" )? Waiting for your reply, ths again! giantice 22th Jan 2007 --- Quote Start --- originally posted by hippo@Jan 22 2007, 11:44 AM you are very close to finish.you need to install bison package for ftpd, or you can disable ftpd.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20750)
--- quote end ---
--- Quote End ---
Yes, you can disable ftpd with make menuconfig, Customize Vendor/User setting.
How to install bison package, depend on which Linux distro you use. - Altera_Forum
--- Quote Start --- originally posted by hippo@Jan 22 2007, 01:20 AM yes, you can disable ftpd with make menuconfig, customize vendor/user setting.how to install bison package, depend on which linux distro you use.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20753)
--- quote end ---
--- Quote End --- I had the same problem using Ubuntu distribution because by default bison package is not installed , but I was able to easily download and install bison package (debian) from unbutu package site (http://packages.ubuntu.com).
Hi hippo,
I success make the Kernel and start "nios2-terminal" routine by your advice, thank you very much! It can really port uClinux on my own board. But I found my Jtag Uart has some communication problems, so the uClinux debug can't run normally. How can I change the Jtag Uart serial to Uart(Rs-232) serial? I can't found the configuration choice in "Customize Vendor/User setting". And I found the size of image file is too large for me. For example the Net application is not necessary for me. How can I exclude the application, reduce the imgae size, and get a minimal zImage file? What's more, the flash on my board is 2MBytes, I found that after I try "elf2flash" to generate .flash file, the file generated is sum up to 2.7Mbtyes. So how can I reduce the .flash file size? Looking forward to your reply, ths! giantice 22th Jan 2007 --- Quote Start --- originally posted by hippo@Jan 22 2007, 02:20 PM yes, you can disable ftpd with make menuconfig, customize vendor/user setting.how to install bison package, depend on which linux distro you use.
--- quote end ---
--- Quote End ---
Ths your advice, I use the Fedora core 4 in VMware, mybe needs to search the package by myself.
--- Quote Start --- originally posted by bigboss25+jan 22 2007, 04:04 pm--><div class='quotetop'>quote (bigboss25 @ jan 22 2007, 04:04 pm)</div>--- quote start ---
<!--quotebegin-hippo@Jan 22 2007, 01:20 AM yes, you can disable ftpd with make menuconfig, customize vendor/user setting.
--- quote end ---
--- Quote End --- I had the same problem using Ubuntu distribution because by default bison package is not installed , but I was able to easily download and install bison package (debian) from unbutu package site (http://packages.ubuntu.com). <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20755)</div> [/b] --- Quote End ---
login as root , run, "yum install bison" .
