19 years agouClinux to personal NiosII board
hi, I saw the new release of uClinux for Nios on your site: http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist) ...
19 years agoHi hippo,
I success make the Kernel and start "nios2-terminal" routine by your advice, thank you very much! It can really port uClinux on my own board. But I found my Jtag Uart has some communication problems, so the uClinux debug can't run normally. How can I change the Jtag Uart serial to Uart(Rs-232) serial? I can't found the configuration choice in "Customize Vendor/User setting". And I found the size of image file is too large for me. For example the Net application is not necessary for me. How can I exclude the application, reduce the imgae size, and get a minimal zImage file? What's more, the flash on my board is 2MBytes, I found that after I try "elf2flash" to generate .flash file, the file generated is sum up to 2.7Mbtyes. So how can I reduce the .flash file size? Looking forward to your reply, ths! giantice 22th Jan 2007 --- Quote Start --- originally posted by hippo@Jan 22 2007, 02:20 PM yes, you can disable ftpd with make menuconfig, customize vendor/user setting.
how to install bison package, depend on which linux distro you use.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20753)
--- quote end ---
--- Quote End ---
