14 years ago
uclinux sash doesn't show
win7+virtubox+fedora10+quartus11.0
nios2gcc2008...
nios2linux2008...
i use the DE2-V1.5 demostration ,DE2_NET
and use it to run uclinux
when using the default configuration for kenel, zImage can be generated .
and i download sof and zImage, it's OK ...
but nios2-terminal command has problem .
the uClinux logo can be seen .
but sash don't.
and the message it give is :
Init:Missing TERMTYPE field in inittab
1 Reply
    I have received the same exact error, v1.5.
    Unfortunately, haven't figured it out yet, it seems to be something wrong with the linux kernel itself running that /etc/rc script? I'm using uClinux-dist-20071107, which kernel are you using?
