13 years agouclinux PIO device driver interrupt handler not execute
Hi, Thanks in advance for any help I can get. I have a NIOS2 w/MMU running uClinux v3.7. It's a DE2-115 development kit with Cyclone IV FPGA. I use the PIO megafunction to monitor input rising ...
13 years agoHi,
--- Quote Start --- Do you know a good way to get time(second/usecond)? I tried to use the do_gettimeofday function call in the interrupt handler but with random timestamp return. Sometime it jump back time as well. If you may know, can you kindly point me to a right direction? --- Quote End --- What 'jump back time' means?
* do_gettimeofday - Returns the time of day in a timeval
* @tv: pointer to the timeval to be set
* NOTE: Users should be converted to using getnstimeofday()
void do_gettimeofday(struct timeval *tv)
struct timespec now;
getnstimeofday(&now);
tv->tv_sec = now.tv_sec;
tv->tv_usec = now.tv_nsec/1000;
'tv_sec' will not increase monotonously ? How does the command 'date' response in your shell ? Kazu
