13 years agouclinux PIO device driver interrupt handler not execute
Hi, Thanks in advance for any help I can get. I have a NIOS2 w/MMU running uClinux v3.7. It's a DE2-115 development kit with Cyclone IV FPGA. I use the PIO megafunction to monitor input rising ...
13 years agoHi,
--- Quote Start --- You are right about the irq signal isn't asserted. I took a screen shot of the signaltap II (attached) and find out the chip select and input clock isn't either. --- Quote End --- Did you set the 'interruptmask register' of your PIO core ? And how many frequencies did you use for capturing of Signal Tap II ? Kazu
