13 years agouclinux PIO device driver interrupt handler not execute
Hi, Thanks in advance for any help I can get. I have a NIOS2 w/MMU running uClinux v3.7. It's a DE2-115 development kit with Cyclone IV FPGA. I use the PIO megafunction to monitor input rising ...
13 years agoHi,
--- Quote Start --- All seem correct and compile, but the handler function doesn't seem like it was executed when I generate a pulse signal to the SMA. --- Quote End --- At first, please check whether the interrupt signal (irq No.2 in this case?) is asserted or not. This check is easily done by using your Signal Tap II. Kazu
