16 years ago
uclinux on de3
hi,
i am new for fpga, and now, i need to run uclinux on de3
i follow the wiki step by step, but unfortunately when i use my own my_nios2_fpga.h it doesn't work.
i think i do the wrong sopc configure, so anyone can help me and write something to show how to build the sopc.
thx a lot!
wangyipin
    the errors:
    /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined
    /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if
    /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c: In function 'main':
    /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:122: error: 'DDR2_LO_LATENCY_128M_BASE' undeclared (first use in this function)
    /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:122: error: (Each undeclared identifier is reported only once
    /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:122: error: for each function it appears in.)
    /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:123: error: 'DDR2_LO_LATENCY_128M_SPAN' undeclared (first use in this function)
    make[3]: *** [arch/nios2/kernel/asm-offsets.s] Error 1
    make[2]: *** [prepare0] Error 2
    make[1]: *** [sub-make] Error 2
    make[1]: Leaving directory `/home/wangyipin/nios2-linux/linux-2.6'
    make: *** [linux] Error 1
    do i have the wrong kernel config?
    can you help me?
    thanks a lot!
    wangyipin
    Hi
    I just search for this solution as well just now.
    Before this i have ported linux on the stratix II developement board.
    I took the DE3_150_DDR2_1G_1RANK reference design from the de3 system design cd and try port uclinux on that system. First problem i encounter is that the nios2-terminal hang after this display on the terminal:
    nios2-terminal: connected to hardware target using JTAG UART on cable
    nios2-terminal: "USB-Blaster [USB 4-1.2]", device 1, instance 0
    nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
    Then i checked the system design again and found that the cpu reset vector and Exception vector are on onchip_mem
    Then I disable the onchip_mem and connect the cpu instruction master and data master to the altmemddr which is the high performance DDR2 SDRAM. Then i reconfigure the cpu reset vector and exception vector to altmemddr, regenerate and recompile the design.
    After all the configuration, the uClinux amazingly boots up. :D
    hi,
    I saw your post about uclinux on DE3,
    I hope you can help me on it.:)
    I want to transplant objects of NIOS(HDMI on DE3) into uclinux.
    but i do not know how to do,
    so, can you give me some advice?
    my email:[email protected]
    thx a lot!
    my regards,
    wangyipin
    --- Quote End ---
