16 years agouclinux on de3
hi, i am new for fpga, and now, i need to run uclinux on de3 i follow the wiki step by step, but unfortunately when i use my own my_nios2_fpga.h it doesn't work. i think i do the wrong sopc...
16 years agothe errors:
/home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "LINUX_TIMER_1MS_FREQ" is not defined /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: error: division by zero in# if /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c: In function 'main': /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:122: error: 'DDR2_LO_LATENCY_128M_BASE' undeclared (first use in this function) /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:122: error: (Each undeclared identifier is reported only once /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:122: error: for each function it appears in.) /home/wangyipin/nios2-linux/linux-2.6/arch/nios2/kernel/asm-offsets.c:123: error: 'DDR2_LO_LATENCY_128M_SPAN' undeclared (first use in this function) make[3]: *** [arch/nios2/kernel/asm-offsets.s] Error 1 make[2]: *** [prepare0] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/home/wangyipin/nios2-linux/linux-2.6' make: *** [linux] Error 1 do i have the wrong kernel config? can you help me? thanks a lot! wangyipin
